CD and DVD Burners
Problem for CD and DVD Burners
Generic problem for all CD and DVD Burners
Error 2131
By FIX_ME_PLZ on Jun 06, 2008
unknown error 2131 appears when trying to use itunes to burn a cd it initializes ect the opens the disc drive and the error message apears i can burn using other programs like windows media player is there a solution to this problem? please help
DVD RW Drive - tsstcorp CDDVDW TS-L632H ATA Device
Comments:
Jun 06, 2008
- SO how do i fix it
Same Problem
Mar 25, 2009
-   I HAVE A NEW LAPTOP AND I WANT TO BURN A CD FROM I TUNES BUT I KEEP GETTING THE ERROR2131 MESSAGE HOW CAN I DO IT WITHOUT USING ONE OF THESE REGISTERY REPAIR THINGS IAM AFRAID I WILL DO MORE DAMAGE THAN GOOD IF I DO -   rOBERTSSNOWY
Mar 19, 2009
-   Cannot burn audio cd's from my Itunes. -   Chicago Deb
Mar 14, 2009
-   Yes I have the same problem. It seems to only occur with Vista. I have a Toshiba Satellite Error 2131 comes on screen when using Itunes to burn a CD. The burning starts, then stops and ejects the CD. -   trspinner305
Jan 29, 2009
-   how to resolve 2131 for free-   ap586
Jan 05, 2009
-   i have TOSHIBA Windows Vista... and when i try to burn CD's on iTunes i get Error 2131...
please help me. Somebody!!!!-   henrydarian
Best Solution
posted on Jul 31, 2008
Very Helpful)
Peyroux
Rank: Apprentice
Rating: 95%, 3 votes
It's Genius, unfortunately while It is attacking the source of the recording ability of the drive I am not that experinced with the registry, so when you say loadTOCNode(3, 'resolution'), I am lost. I need to know how to do that step by step.
Was this helpful?
Yes
No
Solution #2
posted on Jun 20, 2008
Helpful)
kikoksky
Rank: Guru
Rating: 86%, 149 votes
try this:
Click Start, click Run, type regedit, and then click OK. Registry Editor starts.
Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor.
Step 4: Restart the computer loadTOCNode(3, 'resolution');
Was this helpful?
Yes
No
Solution #3
posted on Oct 28, 2008
Very Helpful)
DJOveryde
Rank: Apprentice
Rating: 100%, 1 votes
Hmm ok to translate what that guy said here is the potential solution (testing it out now)
Click Start, Run and type 'regedit'.
In Registry Editor expand to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
Find and Select {4D36E965-E325-11CE-BFC1-08002BE10318}
Optionally just search for the first part of that ({4D36E965-***}
Find and delete both registry keys UpperFilters and LowerFilters.
Exit registry Editor and restart your PC.
Reinstall iTunes so it can reinstall the required registry keys again.
Then try to burn again.
If this does not work the usual other solution is to uninstall and reinstall iTunes again.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Aug 10, 2009
Helpful)
bballplayer9
Rank: Apprentice
Rating: 88%, 2 votes
I had the same thing on my dell and after many hours found out how to fix it. here is a link to the step by step process- hope it helps http://www.ehow.com/how_5242803_fix-burning-disc-failure-itunes.html
Was this helpful?
Yes
No
Solution #5
posted on Jul 28, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the dude
Solution #6
posted on Jul 03, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
dude use words a thirteen year old kid can understand
Popular Solutions for CD and DVD Burners
Questions and Unsolved Problems for CD and DVD Burners
Answer
I need an internal cd/dvd burner drive tray where to buy one
Answer
I am trying to connect ASUS SDRW-08D1S-U with my HP Mini 110 but there is no recognition of this... (More)
Answer
LG GH22NP20 22X DVD RW HAS A PROBLEM THAT IT IS OK WITH DVD BUT NO CD IS WORKING WITH IT. IT MEANS... (More)
13 Other Users Have The Same Problem - Continued
Comment by baird2100, posted on Jan 04, 2009
Goddamn apple and their shitty itunes when I get those songs off there and in my WMP I will never use it again!!
Comment by Guest, posted on Jan 02, 2009
with tdk cd-r certified plus cds I yo am having a 2131 unkown error when attmetingto burn a cd. what's the deal?
Comment by Guest, posted on Dec 20, 2008
2131
Comment by Guest, posted on Oct 21, 2008
Yes i need help error 2131 happens to me every time a try to burn a cd from itunes
Comment by mikedunn21, posted on Sep 07, 2008
I have a acer extensa 5620z with TssTcorp CDDVDW TS-l632h.. Can not burn CD via ITUNES.
Step to resolve : - Hours of searching on internet - not clear what is best.
Comment by Guest, posted on Aug 01, 2008
TENGO UNA PORTATIL SATELLITE A 205 SP5815 CON WINDOWS VISTA HOME, PERO NO RECONOCE EL LECTOR CDDVDW TS L632H ATA
Comment by Peyroux, posted on Aug 01, 2008
I need replacement files for the windows registry otherwise my burner is not recognized. Anyone have such files and how to replace registry files.
Comment by Guest, posted on Jun 26, 2008
I have the same problem on the Acer Extensa 7620 / TSS corp CD DVD W TS-L632H drive. Vista. regedit shows only the UpperFilters key present. Removing this causes iTunes (plus CD burner (NTI) to drop driver and drive shown in Control Panel as unabel to load due to reg. key failure. So after this no CD support on PC making re-install tough. As usual : Do not attempt to perform this (any) fix unless have proper back up / backout point established.
NTI works ok. Can iTurns-burn to RW-cd (and the copy using NTI to CD-R).
Cumbersom but possible.
Have support request # 177-172056 in with Acer.
Pefancop
Describe your CD and DVD Burners problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD Burner Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
