Question about Samsung SpinPoint T133 Series (HD300LD) 300 GB Hard Drive
Samsung HD300LD Hi, I was using the above 300gb drive in an external usb case, I have 2 different ones and when I moved house I may have mixed up the power supplies for the 2 different drives, when i plugged it in it went pop and now the drive does not spin at all, I tried it in a different case with the same results so it is definetely the drive that is dead, advice on if I can recover the data please? and how, Thank you in advance. Lisa.
Teckies
  • 226 Answers
SOURCE: Samsung SP8022N / Hanaro 2
ok.
ok you said that you have hanaro 2 and you want to sasve something to that drive.
this is what you got to do set your hard drive as slave. ok
Posted on Jan 26, 2008
  • 10 Answers
SOURCE: Seagate 300GB USB 2.0, read write error
Hook it to another computer do see if the drive is the issue.
Posted on Oct 04, 2008
  • 265 Answers
SOURCE: USB port broken in 1TB seagate Freeagent external hard drive
Yes you can just take the hard drive out of the case, can use it with any other case, you can also just put it inside your computer and connect it to the sata cable :)
Heres a case you could use for your drive... Click Here
Please rate
Many thanks
Posted on Feb 20, 2009
  • 34 Answers
SOURCE: My segate 300Gb HDD keeps asking to format it when i recently pluged it into a new computer to transfer data to and it said that the driver didnt install correctly. since then it keeps asking to forma
I'm assuming that this was functioning at one point. If you are using Windows, Right click on my computer and click "Manage" Then go to disk management? Does it see the drive at all. If so, has a letter been assigned? It is possible that the operating system will show the drive even if it can't read the data. Look to see what file system and how it sees the disk having been partitioned. It is possible that your partition table has been corrupted. This can possibly be fixed using a tool like disk doctor or fdisk.
If, on the other hand, the drive is also making funny noises, you may have a mechanical failure on the drive.
Posted on May 29, 2009
  • 12 Answers
SOURCE: I have a Samsung G2 500GB hard drive, and every
Sounds like a driver issue with your hard drive. If you have the software that came with the hard drive you may be able to reinstall the drivers. Or, alternatively, look up the hard drive online and download the drivers from Samsung's website.
Posted on Mar 11, 2011
My windows XP OS won't recognize my SimpleTech SimpleDrive Pininfarina 300GB External USB 2.0 Hard Drive
I found that often, external hard drives just don't have any active partitions and thus don't show up in Windows. Go into the control panel, administrative tools, computer management and then the disk manager and see if it has a partition. If it's just unallocated space, right click and make one.
Jan 16, 2012 | SimpleTech Simpledrive Computers &...
I have unplugged my maxtor 300gb external hard drive from one pc and have plugged into my laptop to transfer data. Light goes on but doesnt seem to be showing up on laptop 'My Comp'
you might want to try to unplug to HD's power and plug it back in then plu the USB into you computer....make sure that you remove the usb safely and not just unplug it.
Nov 24, 2010 | Maxtor OneTouch II external hard drive...
Samsung LA40C530 LCD USB limit
I have tested the LA40C530 Samsung with a 300GB external hard disk and it works well without any issue. My guess is that it should support 500GB as well. I have played video/music/pictures on my WD 300GB HDD.
Jul 01, 2010 | Samsung Televison & Video
How to move large data blocks from one PC to another using Maxtor external hard drive
just right click the folder you wont to move and send to the maxtor drive
right mouse click and sent to
Dec 26, 2009 | Maxtor OneTouch II external hard drive...
Installed HP C6380 and lost 2 of my hard drives
Try the drives in another usb port set, for example at the back or the front of the computer in a diffrent set of plugs than where the printer is.
May 22, 2009 | HP Photosmart C6380 All-In-One InkJet...
Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
May 25, 2008 | Maxtor OneTouch II external hard drive...
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
RE: my external hardrive
Check cmos to see if usb ports are enabled? If Windos 2000 you need a usb driver disk.
Feb 28, 2008 | Maxtor OneTouch II external hard drive...
Maxtor external hard drive is not accessable
- Do you hear any beep sound when you plug in the USB drive into the laptop? - You can also try a different USB cable - Try connecting the hard drive to a different computer and see if it works All those steps will help you determine where the issue is. Please revert back with any other observations. Good Luck
Mar 30, 2007 | Maxtor (H01R300) 300 GB Hard Drive
Samsung SpinPoint T133 Series (HD300LD) 300 GB Hard Drive Logo
110 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
