Check these:
Can you hear the "dogs" engaging in the flywheel when you initially pull on the cord?
If you remove the recoil assembly from the engine then will the rope pull out?
Is something preventing the blade from spinning underneath?
Can you turn the engine over manually by turning the flywheel?
If you remove the spark plug will it turn over?
One of these should help determine the problem. Good luck!
Testimonial: "on the right track, I think. "
Instead of asking for clarification here, I made a new post. I'm a newbie here so maybe there's a better way ? Anyway, thanks. Please read and answer my next post if you have time.
