Asrock k7vm2 3 long beeps on power up then nothing. What does it mean please?
  • darkfrontier Jul 27, 2008
    went to upgrade the memory, got 3 long beeps wont turn off just keeps going no visual output wont even get to bios. tried puting the old memory back in to no avail.
  • 46 Answers
Usually bad ram.
Is it POSTing at all? if there are multiple sticks of ram take one out and try again, if it doesn't work, switch sticks. If you have known good ram whack that in and try to boot.
Posted on Jun 06, 2008
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
My bios speaker will beep on startup but nothing more. What avenue should I approach to get past this part of startup?
First you need to know which BIOS you have and how many beeps it is producing... these beeps are the POST - Power On Self Test. They tell us if there are problems such as missing keyboard, video card not working, memory faults etc...
Then you need to go to the appropriate BIOS site and see what the number of beeps mean.
If it is a single beep - it means all is well...
As you are not getting anything more you should check to see if the Hard Drive (HD) light flashes - if so - the HD is probably operating ok and loading your system but there is either a problem with your monitor or video card... borrow another monitor and see if that helps...
But it all depends on the number of beeps you get and what kind - long and short beeps (like morse code).
If this helped you at all please vote!
Oct 06, 2009 | Asrock M266A Motherboard
Pc keeps beeping 3 times and nothing on the moniter
remove the RAM(MEMORY CHIPS) from *********** board and reinsert.if the problem is same replace the chips,get new chips.mostly cleaning the golden lines on the chip with pencil/school rubber solves the problem.
No beep is usually a power problem that can be related to the power supply, motherboard or both. Always check your battery power before thinking there is a bigger problem.
One beep is a normal POST. That means everything is fine. Two, Three, or Four short beeps are normally about the memory of the machine. If there is a problem with one of your memory chips you should get beeps of different combinations in this area. If you get two or three short beeps, one or both of your memory chips could be in trouble.
Five beeps point toward motherboard or CPU problems. Make sure your memory and video card are seated properly. Try removing them and putting them back in, only if you are comfortable with computers. Six, seven and eight beeps. Eight beeps indicate problems with your video card. Six or Seven are CPU, or a bad chip on the motherboard. Nine beeps mean the BIOS is bad. Replace the motherboard. Ten beeps means the problem is in the CMOS. All chips need to be replaced.
Jul 11, 2009 | Asrock 775i65G Motherboard
I just installed a used Asrock K7S41GX board which is working just fine exept I have no sound through my external speakers. The internal speaker on the the board beeps on startup but nothing after that. Do...
If you hear just one short beep on the onboard speaker it means that everything is fine. You should download the drivers for the onboard sound from Asrock website.
May 18, 2009 | Asrock K7S41GX Motherboard
No boot and beeps
The exact fault code indicates RAM or a problem accessing the RAM.
Check that you are using recommended/Approved RAM as ASUS and ASROCK (the budget arm of ASUS) are notoriously fussy with RAM.
If it all checks out then your northbridge could be dead and it will probably be scrap.
Feb 21, 2009 | Asrock K7S8XE Motherboard
ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Aug 27, 2008 | HP Compaq dc5100 PC Desktop
Hello I have a motherboard Asrock nothing works
check all possible connections from your power supply to the motherboard.
May 28, 2008 | Asrock M266A Motherboard
Beep Beep Beep
How many beeps? There should be a sequence of beeps. Are they all the same, or are some short beeps and some long? Please clarify so I may help you further.
May 22, 2008 | Asrock K7S41GX Motherboard
Please help me
Check ASROCK P4i45GV R5.0 User Manual Page 17 -
Note: Check Page 11 for the CLRCMOS0 location on the motherboard. From the picture CLRCMOS0 is number 18. You can locate CLRCMOS0 just below the CMOS Cell Battery.
Turn off the computer and unplug the power cord, then use a jumper cap to short the pins on CLRCMOS0 for 3 seconds. Please remember to remove the jumper cap after clearing the CMOS. If you need to clear the CMOS when you just finish updating the BIOS, you must boot up the system first, and then shut it down before you do the clear-CMOS action.
Mar 22, 2008 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
690 people viewed this question
David Payne
David Payne
