FixYa.com
Tags:
Epson >>> IM800 DARK GRAY 733 MHZ CPU 128MB HDD WIN XP PRO  PC Desktop
My computer is restarting over and over
posted by kira37 on Jun 06, 2008
My computer is restarting over and over....It's stating that a program has unexpectedly shutdown and that windows needs to restart. It's a HP laptop
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by jbarreto, posted on Jun 13, 2008
If you cannot restore your machine by starting on safe mode (F8 key while is booting up), then going to start, then "all programs" then "system options" then "system restore (you can choose the last date you remember your machine was working properly)", then your best bet is to just reprogram it. Make this however your very last option. If you can restore your computer in safe mode, I recommend you to open a web browser and under "tools" go to windows update and download the latest security updates for your computer and then run a complete scan for viruses, spyware and anything that my damage your computer. A tune-up will be needed, so defragment your hard disk and run a system cleanup.
Best Solution
Helpful (85)
Paeroa
Rank:Wiz Wiz
Rating: 80%, 455 votes
see if it will start ib safe mode by pressing he f8 key when u first boot up the machine. If it starts in safe mode go to start, all programs assessries system options, system restore. Try restring your machine to and earlier date like when you had n problems......cme back here if it dnt work
Rating Locked! (?) kira37 has rated this solution as Helpful
Solution #2
posted on Jun 16, 2008
Not Rated (0)
Open SKy
Rank:Wiz Wiz
Rating: 80%, 203 votes
Hello
1) Memory
2) Bad BIOS conf,
3) IRQ conflict, check BIOS
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on Jun 14, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If its restart again and again do check with your antivirus as its indicated that your system contains viruses.plz do check it and let me know if still facing that problem.
Solution #4
Not Rated (0)
spyderz343
Rating: 0%, 0 votes
Also check your fans, it could be over heating
Solution #5
Not Rated (0)
Wybmasiity
Rating: 0%, 0 votes
If it gets into windows and then shutsdown after a very short time. Then start it again and click on the start menu A.S.A.P. click on the run command and enter:
shutdown -a
Then O.K.
If it no longer shuts down after typeing in that command then you have a virus and need toi run anti-virus software to clean it out. If this is the case then you also have the virus in some of your restore points and they need to be cleaned out as well.
Good luck. Be more specific about at what point it starts to restart.
Solution #6
Not Rated (0)
wolf68
Rating: 62%, 2 votes
at what point does it restart? is it random or is it right after you login to windows, ect...? this will make a difference as to what steps are needed to fix the problem if the system restore doesn't work.
Can you Help with these PC Desktops problems?
PC Desktops
i have a lexmark x5470
i have a lexmark x5470 printer... Answer This...
PC Desktops
I cant open an Email
I cant open an Email acc it... Answer This...
PC Desktops
I can't seem to open
I can't seem to open most of my... Answer This...
PC Desktops
I CANNOT READ MAIL BECAUSE
i cannot read mail because... Answer This...
PC Desktops
d-link dwl-g630 has stopped...
d-link dwl-g630 has stopped... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
