Question about Denon Audio Players & Recorders
Denon unit doesn't power on. No nothing! i believe the power supply went bad. Its a 2307CI is this a common problem?
Might want to check the fuses some time over a peried of time the tens to blow. check all fuses
Posted on Jun 06, 2008
Can I make the Denon AVR-2307Ci receiver have a passthrough for 3D?
I believe it is like my Denon AVR-3808 as it's a HDMI v1.3 compliant. For 3D you need 1.4. So I now use optical cables to the AVR and HDMI to the TV. Then config the DNLA player to split the video to HDMI and the 5.1 sound to optical.
Jul 15, 2014 | Denon AVR-2307Ci Receiver
Cannot get new DVD player to work on Denon AVR-2307CI Receiver
TRY TO FIND DVD PLAYER RESOLUTION SAME TO THE RECEIVER....MAY BE IT WORKING..
Dec 28, 2013 | Denon AVR-2307Ci Receiver
I reinitialized my 2307ci receiver and cannot get on on screen menu
I had a similar issue with another denon model solved it by buying a cheap replacement remote for denon multiple models, make sure it covers your model. It looks better than the old one and covers every function.
Dec 23, 2013 | Denon AVR-2307Ci Receiver
We were listening to music , cd , & a buzzing sound came over sound system then nothing. no functions work at all. Main board lights up but that is it.
If the screen lights up then shuts down this could mean it's going into safe mode the other option is that part of the power supply could of failed this is normally only a capacitor or resistor
Aug 03, 2013 | Denon AVR-2307Ci Receiver
Problem denon avr 1910
most electrical units have a fuse inside,try taking cover off and checking for blown fuse,or,take it to radio repair shop.My Harmon Kardon stopped after 3 years,and the report said the unit that failed was quite a common problem for the modern multi channel amps,quite cheap to fix..All my tips are free
Jul 04, 2010 | Denon AVR-1908
My Denon avr-2307 have a dead LCD display
If you can solder, you may be able to fix this. Many of these that I have seen have poor solder connections at the display itself. Carefully open up the unit and locate the rear of the LCD panel. There should be a long line of connections. Check the ones on either end. These are the supply and ground connections. Quite often these connections crystalize and break. Resolder them and try the unit again.
Let us know if that resolves the problem.
Thanks,
Dan
Sep 14, 2009 | Denon AVR-2307Ci Receiver
Denon AVR-2307CI HDMI won't always connect
In short, HDMI will not work. HDMI is riddled with issues, your's is just one of many! HDMI version 1.1,1.2,1.2a,&1.2b do not work 100% on any receiver. The current version is 1.3b and "so far" it works... Now the bad news; It's not just a software patch to fix the problem, it's a hardware issue as well. If your unit is still under warranty, the manufacturer will update hardware and software for you at N/C. If it's out of warranty, it's way too expensive to have done! The fix is to run your HDMI directly to your TV from source, ie. Cable,DVD, etc. then run coaxial digital or optical to your receiver for audio. The catch.. How many HDMI inputs your TV has will limit sources hooked up via HDMI. If you want further info on HDMI issues, just google "HDMI forums" and there are many different sites to answer the problems of HDMI. Hope this helps.
Aug 23, 2009 | Denon AVR-2307 Receiver
I just hooked up my wii to my Denon AVR-2307CI receiver and have video but no audio. I set component in assignment to VCR-1 and put Green/Blue/Red in comp 1 and Red/White in VCR-1 in Audio IN
Most likely the VCR1 input in the Denon is set to a digital input, you will need to go into the setup for the VCR1 input and make sure that NONE is selected for the digital audio input.  Also - make sure you did not plug the Red/White audio cables from the Wii, in to the VCR OUT, instead of IN.
Mar 10, 2009 | Denon AVR-2307Ci Receiver
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
104 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
