Power supply the power supply is damage. I do have psp but do I have to take it to the store? or can the power supply just be sent to my house
  • pontes Aug 13, 2008
    Power supply is broken. When ac cord is plugged into a working outlet charging light does not come on. When computer is turned on it only runs on battery power
  • 191 Answers
Call the support for your computer or you can purchase it from Best Buy or a local computer shop
provide them the model number for your system
Posted on Jun 06, 2008
  • Rahil Kamra
    Rahil Kamra Jun 06, 2008
    if its a Dell provide the service tag i'll provide you the right part number.
I have a psp1000 it was fine until is started powering down all by itself. i put a brand new battery in it and shortly after it powers up, it powers down. What do i do now, and would it be very expensive...
Here are some instructions to help fix your problem.
Put the PSP down on a table with the LCD screen facing up.
  • 2 Plug the power cord of the PSP power supply into the PSP's power outlet. Plug the AC plug of the PSP power supply into an AC socket.
  • 3 Perform a hard reset on the PSP by pushing up on the power switch at the lower-right corner with your index finger.
  • 4 Count to 15. Release the PSP's power switch. Count to 30.
  • 5 Flick the PSP's power switch up with your index finger and release it. Repeat this procedure a second time.
  • 6 Wait as the PSP reboots, starts up and stays on.
  • 7 Remove the PSP power supply's power cord from the PSP's power outlet. Remove the PSP power supply's AC plug from the AC socket.
  • 8 Flick the power switch up with your index finger to turn off the PSP.
  • May 05, 2011 | Sony PlayStation Portable (PSP) Console
    Need Some Help, My Psp 3001, Turns Off On It's Own, While I'm Playing A Game Or Listning To Music, What can i do???
    Here are some instruction to help fix your problem.
  • May 04, 2011 | Video Game Consoles & Games
    PSP 2000 power on for 20c and then shuts off
    the power supply is damaged and it has tobe replaced.
    Dec 23, 2010 | Sony PlayStation Portable (PSP) Console
    Power supply problam in sony tv g14
    If the power supply is damaged, you would have to do a warranty repair. The power adapter can be replaced. What is the problem exactly?
    Mar 15, 2010 | Sony PlayStation Portable (PSP) Console
    WLAN Ad-Hoc Mode Dont Work..T.T
    Just hack your psp and download the game for free
    Jan 03, 2009 | Sony PlayStation Portable (PSP) Console
    My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    PSP Will not start
    What hapenned to all your PSP's is that they 'bricked'. When your PSP is installing an update and you interrupt the process, the data where the PSP's operating system (=firmware) is stored got corrupted (=broken). In very rare cases this can happen when you play a game and something goes wrong due that game. When your PSP is bricked the green lamp is on but the screen stays black.
    Now straight to the point..The solutions:
    1.If your PSP 'bricked' because you interrupted a system update (Powered off while updating, canceling update..), then you can only help it by re-installing the firmware correctly. NOTE: This is unsupported by Sony and is something you do on your own risk, for a usual PSP user it is a complicated process and i suggest you should let someone with experience do it. If you still want to attempt it, for example here's a tutorial for making a 'pandora battery' : http://www.youtube.com/watch?v=ZKFnuCfTPZo
    To find more information about this subject you could seach on google for tags like 'psp pandora mod custom firmware jigkick'
    2. If your PSP suddenly doesn't start up after or while you played a game, then you have a chance that you can recover your PSP without too much hassle. Simply let your battery run empty. After it's empty, remove the battery and let your PSP 'rest' a day without battery. After that, reinsert the battery, first fully charge it, and THEN start your PSP up (after your battery is fully recharged). If you have luck you might have your PSP working again.
    3. Contact Sony and explain the situation. Explain that you did nothing wrong. If your PSP is still under warranty they should help you..
    Good luck and if i helped you please leave feedback! Thanks
    Sep 02, 2008 | Sony PlayStation Portable (PSP) Console
    ACCESSORIES:BATTERY
    I used to work at Best Buy so here is the scoop. Bring in your notebook ASAP to Best Buy. Take it to the Geek Squad counter and tell them that you have a service plan and would like a new battery. Under your service plan you are entitled to a battery replacement. What they will do is order you a new one, and have it sent to the store. They might tell you that you have to have it sent off for service, but in actuality they can just send the order in without your notebook. As long as you go in prior to the expiration date, and the order is sent in before the PSP expires, you should be fine.
    May 09, 2008 | Samsung V20 XVC 2400 Notebook
    Power
    1. Make sure the AC outlet is good.
    2. Make sure there is no damage to the AC line cord.
    3. Look to see if there is a fuse at the rear of the unit. It's usually located inside a black circular housing with a screw off cap that says "fuse".
    If not, unplug the unit and remove the outside cover. Look for a blown fuse on the motherboard or power supply. Replace it with the EXACT value of the original fuse. You can purchase a new fuse at Radio Shack or hardware store or auto parts4.gif store. Try powering up the unit again and see if it works now or whether the fuse blows again. If it blows again, the power supply may have been damaged.
    Please let me know if I can be of further assistance to you.
    - Jim
    Mar 19, 2008 | Onkyo TX-SR601 Receiver
    Power Problems
    there is a problem in the connection between the battery and the psp itself. u could open it to check it out or u could get it sent to a technitian. if its in warrenty, send it back to sony, but dont tell them about the dropping part
    Mar 16, 2008 | Sony PlayStation Portable (PSP) Console
    Computers & Internet Logo
    18 people viewed this question
    David Payne
    David Payne
