Question about Magellan eXplorist 500 GPS Receiver
NMEA communication does not work ( but file transfer is OK)
Problem is with NMEA communication from Explorist 500 to OziExplorer ( or Hyperterminal). Equipment: (Dell Inspiron 1100 with Windows XP - Explorist 500)
Windows New Hardware Wizard shows appropriate dirver is oem45.inf for NMEA mode, and another oem65.inf is presumably for USB mode ( I haven't checked this).
Explorist Settings:
-Menu/Adv.Features/Communications/NMEA Data Com/V2.1GSA/NMEA->COM
-"secret" menu 40 check baudrate 4800 -startup, find satellites and locate position
-plug in to computer USB (with cable right way round, tail downward!) -check with Windows Control Panel/system/hardware/device manager: Explorist on COM7
-also tried simulate mode on Explorist, simulated trace appearing on local map
OziExplorer (build 3.95.4q) configuration:
-GPS : Magellan USB -COM: COM7, 1 stop bit, no parity, NMEA baudrate 4800, Serial Driver 2
-Upon starting Moving Map NMEA start I get no error message, in contrast to case of disconnection or wrong COM port.
-Moving Map/ Show GPS Fix or Show NMEA In window Input and Output boxes remain blank.
Hyperterminal on COM7: -nothing.
OziExplorer's GPSPortCheck:
-shows no NMEA message on any port, including COM7
I conclude that various software under Windows recognise Explorist connection but see no NMEA messages. In file transfer mode, the Explorist appears and works correctly as an external drive. I read that NMEA protocol does not use handshake, so assume that Explorist should not wait for appropriate trigger before sending NMEA position sentences but I have tried moving GPS around or simulating movement in case it only reports changes... still no signal. I have tried Explorist 500's Menu/ Clear Memory to try and get a fresh start. I assume for now that the problem is with the Explorist or the Windows drivers, can anyone suggest a method of restarting from scratch to get it going?
Try rebooting windows, with gps off connect the cable to gps.
Go out side get a good gps signals on nav menu.
Set the gps communications menu to , nmea, 2.1
Plug the device into a good usb port.
If you look under modems, in control panel you should see a new modem called explorist xxx
If you look at the properties for that you can see its com port number.
I just tried this program http://www.visualgps.net/VisualGPS/
and it views nmea from the explorist, just set the com port to the one in the explorist modem .
Posted on Jun 26, 2008
My explorist Gc unit...on start up is looking for an active tracking file which is missing. I have a copy on my desktop. How can I get it back into the unit?
You can download the US basemap for the 500 at
http://www.megaupload.com/it/?d=EJTNQH03
Rename it BASEMAP.MGI
Then copy it in the directory "background maps" in the SD card of your 500, by using a SD card reader/writer.
Insert the SD card in your 500 and connect it to your PC; then turn it on;it will turn on regularly, because the basemap in the card will be detected; turn it to USB file transfer mode, and copy the basemap from the SD card to the directory "background maps" of the 500.
If you already have the file ..just rename it like I said ..and copy it ..using the sd card in the reader...Than if it is not functional ..just reset it ..and reload the file the proper way by reloading maps..
Aug 28, 2011 | Magellan eXplorist 500 GPS Receiver
Error Message on Explorist 500
With you 500 turned off press nav + power; then change the numbers 00 in 95 by using the joystick and and then press the joystick itself; accept what proposed.
after turning the gps on again and pressing enter the NAND will be configured and your gps will become in order again. if necessary, in usb file transfer mode, reload the basemap in the directory background maps
Jun 10, 2008 | Magellan eXplorist 500 GPS Receiver
Track Files
We are taking more waypoints to link up the track points on the map to make it more accurate. Thanks
Mar 04, 2008 | Magellan eXplorist 400 GPS Receiver
Magellan Explorist 500 LE Power
eXplorist units have also some hidden and service functions. Like, if unit is off, you can to press:
- IN + PWR - to full selftest of unit (screen test, keypad test, NMEA test)
- OUT + PWR - to serial port test
- ESC + PWR - to burn-in process
- LIGHT + ENTER + RWR - tp uploading of new firmware
- NAV + PWR - to call Service Function window (see below)
- NAV + MENU + PWR - to force power off, equal remove batteries.
- GOTO + OUT + POWER - clear memory and set all settings as default.
IN + PWR helped to power up my unit.
Feb 24, 2008 | Magellan eXplorist 500 GPS Receiver
EXplorist 500 Background Maps
The basemap file is a system file.
So you see nothing if explorer, in your PC, is setted for not showing system files.
If you change this setting you'll immediately see the file
Feb 17, 2008 | Magellan eXplorist 500 GPS Receiver
Unit Map
Feb 02, 2008 | Magellan eXplorist 500 GPS Receiver
Explorist 500
Dec 28, 2007 | Magellan eXplorist 500 GPS Receiver
Fault mesage on screen when first strat magellan 500
Sep 04, 2007 | Magellan eXplorist 500 GPS Receiver
USB drivers
I have a same problem, but it was solved.
You can go to magellangps.com website, then go to support.
There you will be able to download the driver.
But you may need to register first.
Happy trying.
Aug 25, 2007 | Magellan eXplorist 210 GPS Receiver
Finding the user name
You must use the RS-232 serial cable using terminal emulation software such as Microsoft HyperTerminal. Connect the cable from your computer to the console port on the DSL-500 or DSL-504. Step 1: Go to Start>Programs>Accessories>Communications>Hyperterminal. Step 2: Enter a name for your connection and choose the default icon selected. Step 3: Select a COM port (usually 1 or 2) and click OK. Step 4: The terminal parameters will need to be set to as follows: Step 5: At the command prompt type isfs cat inituser and press enter. You will now see the username and password.
Feb 16, 2006 | D-Link DSL 500 (DSL-500) Router
Magellan eXplorist 500 GPS Receiver Logo
1,159 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
