Question about Electronics - Others
USB drive write protected
We just bought a USB drive and were using it for the first time to transfer files from our old computer and it says now it is write protected in the middle of it. Best buy suggested using this instead of the easy transfer cable. Can we get the write protection off or is it just unuseable?
    Novelist:
  • 104 Answers
If you can replace it for a new one that would be the best thing to do, otherwise there is software to try fixing it, if this will be your choise please come back for more information.
Posted on Jun 13, 2008
  • 94 Answers
The drive has gone faulty.
get a replacement fm vendor
Posted on Jun 12, 2008
Recently , you purchased a USB flash drive that you plan to use to store work-related files. When you attempt to store a file on the USB flash drive, the computer displays an error message indicating that...
You failed to mention what operating systems are involved. What does the work computer use as an operating system. The file system format of the USB may be say as an example ntfs windows while as a hypothetical the work computer could be apple o/s using a different file system or even maybe a unix system. You may need to reformat the usb stick to be the format file system used by the work computer. Also there could be a policy in place to prevent usb sticks working on work computers to protect intellectual property or to protect against virus transferance.
Sep 25, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
How do I transfer files from old computer to new
You can't transfer programs, programs have to be reinstalled.
You can copy things like your My Documents Folder, My Pictures, My Videos, and Favorites to a usb flash drive or an external drive then put the drive into the usb port of the new computer and copy them to the appropriate folders (Documents, Pictures, Music, Videos, etc).
Apr 07, 2012 | Acer Aspire 5050 5430 Laptop
How do I download all my stuff from my current computer to a new computer?
You can easily and safely use a USB pen drive with a large capacity to transfer all the files one by one , folder by folder with special markings to note the copy into the respective drives. You can also segregate the new drives to your need with personal files, general files and public files. Also picture and video downloads also can be listed and saved.Connect the USB to the old PC and transfer by copy or cut , then connect the usb after safe removal to the new PC and pasting to the new location.
Jan 06, 2012 | Computers & Internet
How do I access my photo's on my old computer that has noplace to add a connection?
does the old computer have USB ports??? if it does than it's just a matter of connecting a USB stick and transfer the photos to it... you could also use a USB external hard drive, or a USB flash card reader, also a USB camera (the kind that taks pictures) not a web cam!!! you could even connect a Cell phone or Black berry equiped with a SD card and use those devices as a drive to transfer the files as well... you could also use the old computer to e-mail the files to your own e-mail and pick them up with an other computer by loging on to your e-mail account and save them... you could even take out the old computer's hard drive and install it in an other computer and transfer the files... When there's a will there's a way (or relatives) LOL!
Cheers!
Sep 09, 2011 | Computers & Internet
How to download my file from my old computer
The simplest way to transfer files from your old to your new computer is by using USB flash drives. Just save your files from the old computer onto the flash drive then plug this USB drive in to the new computer and save the files there. If you have large files, you can also use an external hard drive to copy and transfer files.
Mar 22, 2011 | Computers & Internet
Can't transfer my email files from old computer to new computer
Good Day!
To transfer files from an old computer you can use USB or flash drives, copy the files from your Old Computer to Flash drive, after copying---attach the flash drive to your new computer then copy the files and save it. This is the easiest way to transfer files.
Other way of transferring;
-You can also transfer files by Burning your files into a CD/DVD and copy it to your new computer.
-Get your hard disk from the old computer and attached it to your new computer
-Or connect/network your two computers.
I recommend USB or Flash drives, the simplest and easy way.
Hope I was able to help.
Jul 16, 2010 | Microsoft Windows XP Professional for PC
I'm trying to sync my files from my old computer
no you can what you have to use is files and setting transfer wizard in windows xp you can start the Files and Settings Transfer Wizard by clicking Start on the computer running Windows XP, pointing to All Programs, Accessories, System Tools, and then clickingFiles and Settings Transfer Wizard. (If both computers are running XP, you can start with either one.)
just select "i want create wizard disk in following drive " and select you external disk drive tha will do the trick...
Apr 11, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
Usb memory stick
If the old computer is running XP.. then patch it up with service pack 2 and then transfer the files!
Most often service pack does the job.. Also the transfer is fast with the SP2 installed
Apr 08, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
How is transfering Data and information from my computer into 1GB USB2.0(Data Traveler) done?. How do I start and how do I connect the USB2.0 on my computer to begin the transfering?. I am asking this...
FOR ADDITIONAL INFORMATION ABOUT FLASH DRIVES
USB (Universal Serial Bus) flash drives are high-speed, high-capacity memory devices designed for long-term data storage and easy transport among PCs. The host PC treats the device just like a drive, so you can transfer files of all types to and from the device. Because the device emulates a drive, it supports any type of file, including audio files (such as MP3s) and graphics files (such as JPEGs [Joint Photographic Experts Group] and BMPs [bit map]). In addition, USB flash drives can easily support applications, CAD (computer-aided design) drawings, and a wealth of personal information you'd rather not leave on any particular PC. Even so, most USB flash drives are smaller than a pack of gum and can easily fit onto a key ring.
Years ago, users often referred to the practice of using floppies to transport files among PCs as sneakernet. Because USB flash drive manufacturers designed these devices for transport among PCs, their increasing popularity has given rise to a "new sneakernet."
Mar 09, 2008 | Computers & Internet
Electronics - Others Logo
67 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
