Question about Samsung SyncMaster 740N 17" LCD Monitor
Display Problem When I set resolution 1280*1024 pixels it says not optimum mode n screen goes black and I have to press any key to remove that black out......what to do please help me...........
  • Anonymous Jun 09, 2008
    i also has the same problem, when i turn the resolution to 1280*1024 it turn black and back to 1024*768
    Problem Solver:
  • 4 Answers
Also try to lower the refresh rate of the monitor. a higher resolution works with lower refresh rate
Posted on Jul 14, 2008
  • 558 Answers
Video card may not be capable of that resolution and color depth, check your video cards max resolution and color depth.
I have several lcd monitors that are 1280x 1024 and they do not need drivers to work. the video card must be capable of generating that resolution.
Posted on Jun 19, 2008
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Oct 14, 2012 | Computers & Internet
Not optimum mode
This means that your resolution (the amount of pixels) is not the same as your monitor's recommended setting.
The easiest way to fix this is to go into your display settings (right click your desktop and, if XP: Properties->Settings or if Vista/7: Screen Resolution) and drag the slider all the way to the right (XP) or top (Vista/7).
If the highest setting makes your screen go blank for more than 5 seconds, press Esc and try the next setting down. Do this until your monitor correctly displays the highest setting allowed.
Mar 27, 2010 | Samsung SyncMaster 710m 17" LCD Monitor
''not optimum mode'' icon continues to show
this is not the problem with your monitor. Pl boot your computer with enable vga mode. in vga mode set your resolution into 1680 x 1050 with which color mode you need set ok
it will be ok. After restart, your computer will ok. even the problem retains, pl reinstall the video driver and try again. give me ur feedback
Aug 25, 2009 | Samsung SyncMaster T200 LCD Monitor
Monitor problem: not optimum mode recommended mode: 1280x1024 60 hz ? cannot click on screen. Samsung model 913T s
It appears your display adapter is set to a different refresh frequency or resolution,
either accidentally or due to some power glitch.
If you cannot set the resolution because this message is preventing you from getting to the
display settings window, try rebooting your PC in Safe Mode. It'll take a while longer
than usual, but when you're finally running, try setting your display adapter to the
1280x1024 60Hz settings. This is available under "Advanced->Adapter->List all modes".
To reboot in safe mode, try pressing the PF8 keys repeatedly after the POST messages
disappear just after turning the power on. This only works if this key is enabled to
operate from the BIOS settings.
To get to the BIOS setup, Look at the first messages displayed on your screen indicating what key to press. It's usually the Delete or PF2 key, but different BIOS manufacturers use different keys.
Once inside the BIOS setup, find the way to enable the PF8, PF9, PF10, keys. Save your
settings and reboot.
Now you may try PF8 again to go to Safe Mode.
Good Luck!
Aug 19, 2009 | Computers & Internet
Not optimum mode
This means your computer windows resolution is not display in the correct resolution which your samsung LCD will take.
What you need to do it boot the computer in safe mode. (pressing F8 at start up and select safe mode) This should bring the windows to start up in the generic 800x600 resolution.
Once you are able to see the display in safe mode, go onto the display properties and change the resolution.
* right click on desktop -> properties -> settings
Please rate this if it solves your issue. If you need further assistance please post.
May 29, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Screen resolution reminder.
go to the control panel double click DISPLAY then select setting then select 1440x900
Jan 09, 2009 | E-Machines eMachines Desktop PC
Screen blank
Sounds like its simply going into power save mode. Does your screen come back on when you move the mouse or press a key on the keyboard? Is the computer still on? Check your power options in control panel.
Nov 29, 2008 | Computers & Internet
My new 22" monitor won't come on
restrat your computer then press continue F8 key untill u get menu
then go to enable vga mode or safe mode or last known god configuration. set your display resolution in display properties to 1024*768 pixel then try.
Oct 05, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Showing "not operating in optimum mode"
reinstall the display drivers in safe mode this you can do by pressing F8 and in safe mode, you can also try restoring the machine to previous state Good Luck
Jan 19, 2008 | Samsung 710V 17" LCD Monitor
Samsung SyncMaster 740N 17" LCD Monitor Logo
173 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
