just scan it using the command from the computer ..after that you will find the job into the manager folder..of the scanner..from there you can send it directly ..or edit a little ..and copy into computer and attach to the email..or ..use the feature from the scanner's program to send it .. make sure you set to scan picture cause scanners have a wizard that you can set to scan image (picture Jpeg ....) or PDF ..document ..
Make sure by making a copy that your scanner is OK, streaks or black bands won't send properly and you need a new scan assembly, Poor line condition is just that, you need a better line or cable, If you go to fax settings and turn off error correction mode it sometimes helps as well.
hello! first you need to click on then scroll down to where it says easy receive, click on that then go back to the main menu showing the date ask some one to fax you some thing this should work good luck brother tech
