Question about Compaq Computers & Internet
When i try to connect to my second laptop using my netgear router and usb adaptar it will not connect to internet a computer frien told me i need sttings from aol as laptop as been wiped and new software installed can you direct me what to do please.
    President:
  • 1,257 Answers
Check if gateway address is present or not .if there it should be correct ..contact your service provider
thanks
dilipbagdi
Posted on Jun 06, 2008
Debug netgear router
I don't think it's the NetGear. Shut down the computer, unplug, remove battery, if applicable, unplug NetGear, wait for 30 seconds or so, plug in Netgear, wait for selftest, plug in computer, reboot. I don't know the laptop or OS you are using so a general idea is all I can give. Does your NetGear have a SSID and Security Password? You can always reset to default settings. That said, I think it's your laptop that the issue. Have you tried to connect via a Ethernet Cable? Have you open the Network Adapters , and disabled and enables, tried a Diagnose and repair ? Have you opened the network and sharing center , Manage Network adapters and remove from Auto connect? Restart and select your wireless, put in your password.
Dec 16, 2012 | Computers & Internet
Router problem. unable to connect wirelessly
This is usually up address conflict. You will have to assign the wifi or lap top to different IP addresses. You have to refer to the modem manufacturers instructions or search on net / YouTube how to do this. It's too detailed to do it here I think.
Oct 17, 2017 | NetGear WGR614 Wireless Router
Have Netgear wndr3300 router...has been in use with main desktop and 2 laptops running windows 7 for some time....son came home from army with an HP running Vista....no matter what we try...will not...
you might try a connection through the modem first to see if you can get a connection
check your son's computers settings ie: firewall also he might have a default internet setting you might have reconfigure all internet settings on his computer
check the leads from the router whether usb,ethernet make sure they are not bad/faulty and have secure connections or try different ports
click start control panel administrive tools computer management device manager scroll to network adapters + to expand any yellow ! ? or a red x will mean that the driver is corrupt and needs to be updated
hope this helps
Jan 17, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I have a acer aspire 5735z and cannot connect to my new adsl modem, telstra ( internet provider) told me to ring acer, will the acer company tell me i need a new drive and will i have to pay for it??? this...
Is your Telstra/Bigpond ADSL modem has a built-in wireless router?
If the ADSL modem has a built-in wireless router and your laptop does not have a wireless card, then you have two options to connect your laptop to the ADSL wireless router/Internet -
1. Purchase a PCMCIA wireless adapter and insert it into the PCMCIA slot in your laptop. One of my favourites is made by Netgear.
or
2. Purchase a USB wireless adapter, the only disadvantage with this solution is, it uses a USB port and if your laptop has only one USB port. This is a problem if you need to connect other USB devices. Then you also need to purchase a 4 port USB hub to give you additional USB ports.
Aug 25, 2010 | Acer Computers & Internet
Connected but unable to view website
You might need to check the security on your router , if its enable or not.
You can try the solution below to check your router wireless security. Note this should be done on a computer that is connecting to the internet thru the router.
1. open browser and enter http://routerlogin.com
2. username is admin , password is password.
3. click on wireless option .
4. look for the wireless security settings.
If you dont have another machine that is connecting to the internet. Just follow the steps below.
1. Reset your router for 30 seconds by holding the reset button.
2. turn off for 30 seconds after resetting it.
3.Power off the modem and turn it back on after 2mins.
4. If all the lights on the modem is stable power on the router, make sure the modem is connected to the internet port On the router.
5. check your computer which has a usb adapter,. Look for the wireless icon, You should be seing an option were in it will allow you to view the available wireless,
6. Look for the wireless name "netgear " and press connect. CHeck if you have internet.
Rate me if the solution is helpful
Kevin angell.
Jun 14, 2010 | NetGear WGR614 Wireless Router
How do I connect my netgear router to my desktop internet to use with my laptop. Followed instructions but when cable is disconnect from my laptop I can't connect to the internet
First Connect the Desktop with Netgear Router with the Ethernet cable. Open the Netgear GUI and configure a Wireless Network. Once its configured, switch On the WiFi switch from your Laptop and try to connect your Laptop. Make sure your laptop has an in-built Wifi adapter, if it doesn't then you would need to buy an USB based Wifi Adapter.
Also if you want to use the Internet with your Desktop PC without being connected with the Netgear Router then make sure it has Wireless connection capability.
May 10, 2010 | Computers & Internet
My netgear usb connects to my wireless belkin..but no internet ?
this message comes when your computer is not getting the IP address from the router.
There are possible reasons for that.
1. DHCP on the router may be disabled.
2. If your network is secured , then you might not be typing the correct network key.
In both the cases , you will need to check the settings of the router.
You will need to access the router set up.
Click Here for more info about router settings
Nov 24, 2009 | Computers & Internet
Can't access configuration for Wgr614 v5 Netgear Wireless router
Since you cannot ping the router, first thing to do here is to reset the router by pressing the reset button of the router for 30 seconds while power is On and then after the reset power off the router for 5 seconds and then when the router is already power On try to ping the IP of the router using a computer that is wired to it if still cannot be ping better contact Netgear support if the router is still underw arranty and have it replace...
Dec 22, 2008 | NetGear WGR614 Wireless Router
I having problems connecting a netgear 54 rt usb adp router to virgin broadband.Router is saying there is an internet connection but computer displays cannot display page and no connection.PS3 has picked...
on your computer try to reinstall the device driver for wireless. try to connect the ethernet cable directly to the computer. if you have internet access, then most likely your netgear router needs to be reconfigured. you need to contact your internet service provider or router manufacturer for the reconfiguration of your router. mostly likely the security settings of the router needs to be changed.
Sep 16, 2008 | Computers & Internet
Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
so your trying to use a dsl router as just a router -dsl with dialup?
Aug 06, 2008 | NetGear Computers & Internet
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
