Question about ASUS P5K-V - Motherboard - ATX - iG33 - LGA775 Socket - UDMA133, Serial ATA-300 , eSATA - Giga...
Bios conf for pci-e card
Can't manage to install my ati 2600pro card on my p5k-v sokket775 motherbord. i diabled the onboard card in the internal graphic mode but then i get a black screen and my onboard graphic card is not working too and i have to resart the cmos jumper and battary.
i checked the ati card on another computer and it work's gr-8.
how can i get my card to work?
plz help me.
  • 1 more comment
  • bulabula Jun 22, 2008
    thanks for you're help but i think i figured the real problem.
    i checked the ati card on the computer with another LCD screen and it worked just fine.
    i have a new sumsung 971p screen and it seems that only my screen doen't want to display with this card.
    i need another solution.
  • bulabula Jun 23, 2008
    if you'll read carefully my friend i wrote : "new sumsung 971p screen "
    the refresh rate of the screen is set to 60HZ as default the next option is 75HZ.
  • bulabula Jun 24, 2008
    yes it doesn't change anything.
    besides, why would the graphic card care about the screen refresh rate? and if it did wouldn't it prefer the lower choice?
    Sergeant:
  • 458 Answers
Try it without disabling the onboard video. It might be possible to use both. I know someone who has this board, so I can check for you later. Let me know if you still have trouble. I will have this person do a test for you if you need one done. You might need to flash the BIOS. That is a fairly new board. I just built a system with with the maximus.
Posted on Jun 22, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Could be a resolution problem with that monitor. If you want me to check with the person with this board, I will. First change the refresh rate if possible. You could also try to hertz on that monitor and see if the can get higher. How old is that monitor that you want to use. What brand and type is it.
    Did you try the 75 Hertz?
Trying to install ATI FireMV 2400 256mb pci-e card. I have a new pc with asus m4a78lt-m motherboard, athlon x4 645 3.1ghz processor, 3gb ram, windows 7 32 bit os, 500w psu Card installed in pcie x1...
First off all reset the bios to default setting and restart the system. After restarting the system please go to your bios in the graphics segment and select auto option for card selection.
once done save all setting connect your monitor cable to your monitor and restart the system.
hope this will solve your problem.
Apr 14, 2011 | ATI FireMV 2400 PCI Video Card
I have a motherboard with an Integrated ATI HD 4200. When I install my EVGA GeForce 8600GT the fan runs but the card itself is not detected in device manager or anything like that. I disabled the onboard...
You don't disable it from there. Reenable it again and do it right: you uninstall its drivers from Programs and you reboot twice; you install the new card and you connect the monitor to it; when the pc starts you go directly in the BIOS and you disable the onboard card from there; you reboot one more time and you install the drivers for the new card.
Feb 26, 2011 | Evga e-GeForce 8600GT, GeForce® 8600 GT, ...
I need to diable the onboard video card before installing a PCI-E 2.0 graphic card. From what I have read, it's possible this is done automatically, through BIOS, or by a jumper setting. I never received...
It is an option in the BIOS under "Advanced Bios Features". Set Initial Display to PCI Express VGA card. Your options may be slightly different due to different BIOS.
Jan 30, 2010 | Gateway GM5472 PC Desktop
I am installing a new saphire graphics card on an ACER M460. Dont know what slot to use. Also, the istructions tell me to remove any exsisting vga card and to disable any on board graphics capability from...
Open cpu cabinet there is PCI card slot fix your graphic card into it.
Some graphicc card is SGP card Check on motherbord you find 1 slot AGP above PCI slot fix your card into it if it is AGP.
Motherbord has normally 3 PCI slot.
AGP card is always 1.
For disable onboard graphic.
When you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to advanced and vga configuration disable vga there .Then save settings and exit.
Let me know if you need further assistance.
Nov 16, 2009 | Computers & Internet
My computer won't detect ATI RADEON SAPPHIRE X1550 256MB
go to bios and enable it to detect graphics cards most bios have an option for onboard only or onboard and external graphics adapters
May 04, 2009 | Sapphire ATI RADEON X1600Pro 512MB...
Problem with Pundit-R and PCI graphics card
I had a similar problem when installing a GeForce 5200 256mb PCI card in my Asus Pundit-S running winxp which I overcame when I got the sequencing of installation right.
First, Physically install the card in one of the available PCI slots. Using the onboard graphics to your monitor, boot the system. Windows will detect your new card and prompt you to install. Cancel Windows installation and use the supplied Radeon install disc for driver and program installation. After that, Reboot and enter your system's BIOS. On my system, repeatedly hitting the delete key gets me there.
Now this is where it may differ. In my BIOS, I needed to select the ADVANCED Menu followed by PCI CONFIGURATION. If your BIOS does not have the ADVANCED menu, you may have to upgrade it by downloading from the Asus Global Site. That is a whole other challenge but it is possible...hehe
The two options that need to be changed in the PCI Config Menu are:
Primary VGA BIOS -> PCI VGA Card, and
Onboard VGA -> Disabled.
Save changes and exit BIOS however, on exiting, you will need to unplug the VGA/DVI cable from your onboard port and connect it to your PCI card port. My card will not display the content unless it is plugged in from initial boot so you might have to restart your computer if you are not quick enough to catch that boot cycle.
Selecting these options should avoid any onboard conflict between devices as the Pundit-R has an onboard Radeon 9100 chip. I suspect the two same-make chips is where the conflict problem lies plus you don't need to be running the onboard graphics if you have a dedicated PCI card.
I hope this helps.
Good Luck.
Sep 18, 2008 | ASUS Pundit-R Barebone
Need help disableing onboard video, and installing PCIe video card.
Hi rebelel1271, I do have the manual for you're Intel motherboard. You can have it as well. Click on the link below to download you're manual. document.write("D101GGC Product Documentation & Manuals") D101GGC Product Documentation & Manuals
Intel states you do not need to make any bios changes when you add a PCI-Express video card. See this on page 17, PCI and PCI Express Auto Configuration. Before installing you're PCI-E video card, open windows controll panel. Than open add/remove programs. Look for the driver software for you're onboard ATI Radeon X200. Uninstall that software. (If listed). Close all opened windows & shut down windows. Unplug the power cord from the PC. Open the case. Install you're new ATI Radeon X800 PCI-E video card. Double check all internal connections, (In case you may have bumped loose any cables). You're X800 may also have a 3-pin or 4-pin male power connector built on the card. If so, plug power to the X800.
Intel D101GGC driver page.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21#DOC
ATI's web site for the latest driver's.
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
A little information. Once you're PCI-E has been installed. You're system memory will increase.
Good Luck!
If I can help you further, feel free to post here.
Mike
Jun 01, 2008 | Intel D101GGC Motherboard
ASUS P5K motherboard does not detect PCI Express ATI TV Wonder card
type ASUS P5K, tv driver and hope fully you will have to install the driver and if that does not work the go to the bios and there maybe you can do something....hopefully this wil help a little....
May 30, 2008 | ASUS Computers & Internet
Will ati card work in one monitor
Be sure that you have gone into your Bios on your computer and disable the onboard intel card that your using.
Aug 27, 2007 | ATI RADEON 9250, (256 MB) PCI Graphic...
ASUS P5K-V - Motherboard - ATX - iG33 - LGA775 Socket - UDMA133, Serial ATA-300 , eSATA - Giga... Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
