Question about Canon NP 6050 Copier
Light copies when duplexing copies
When copying double sided, the front page copy quality is well but the back side is lighter, when using automatic duplex copying. What is the solution? thanks
  • Canon Expert
  • 1,326 Answers
You can try to replace the transfer and sepperation corona wires and the post corona wires. Also, make sure the corona hieghts are set to the door spec's. If that is not good enough try to replace the transfer unit.. Imay need more info.. for any more ideas..
Posted on Jun 07, 2008
When I make a Duplex copying,it is copied at the wrong position only on the front side.
check that you are using duplex and left binding. also does this happen with other files??? does it happen with different program pdf , word etc.
Oct 20, 2015 | Sharp Mx-2310u Color Copy/print/scan
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
How to copy 2 sided
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for the rest of the document.
I suggest you try a test page first, to get the printing the right way up on both sides of the page so it reads correctly.
Mar 31, 2013 | HP Office Equipment & Supplies
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
Jul 08, 2012 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
How can double sided print
HP3350MFP - Duplex Printing/Copying
Hello, The HP3350 does not support automatic double sided printing. The HP3390/3392 printers support this option. In order to double side on the HP3350 a manual duplex will need to be conducted, which means running page 1 through the printer, flip the page over and print page 2 for the reverse side. It may be necessary to experiment a few times to achieve the proper printing orientation. You can download a copy of the users guide from the following link.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=ca&docIndexId=64179&taskId=101&prodTypeId=18972&prodSeriesId=1161389
Jan 15, 2011 | HP LaserJet 3055 All-In-One Printer
Cannnot copy a double sided document to cardstock
This is normal. The cardstock is fed from the manual feed or bypass tray and when selected the duplex option goes away. Many manufacturers do this....meaning they do not allow duplexing from the bypass tray. For the same reason they do limit automatic duplexing to standard or near standard papers. Cardstock is specifically excluded from duplexing obviously due to it's thick nature and when duplexing the paper has to be turned over and go thru paper paths that are not suitable for thick paper. If you must make a 2 sided copy using cardstock you will have to run the sheet thru the machine 2 times, also known as manual duplex.
Hope this helps.
Apr 12, 2010 | Copystar - CS-3035 Printer
How do you make a double sided copy?
If you don't have a duplexer, the larger cover on the back, the only way to copy this way is to re-feed the print, print side up and copy to the back. The duplexer sticks out of the back about 3 inches, the plain cover is just a flat rear door.
Feb 25, 2010 | HP Officejet Pro L7680 InkJet Printer
Double side to single copy w/o paper feeder
Try this.
Set the copy for duplex.
Put the drivers license on the glass.
press the start button.
Turn drivers license over.
Press the start button.
Should copy on both sides of sheet.
If you copier has a booklet setting on it in the duplex. Page the front and back of the drivers license will appear on the same side of the page as well.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
EP 4000 Drawer Duplex
The duplexer is for 2 sided copies. You can take 2 single sided copies and make (duplex) them into 1 double sided copy. You can take double sided copies and make more double sided (2 sided) copies with the duplexer. You can also take double sided copies and make single sided copies. Hope this helps.
Jan 12, 2009 | Minolta EP4000/5000 CS/PRO Copier
Canon NP 6050 Copier Logo
94 people viewed this question
old marine
old marine
