Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Jvc av48wp74 horizontal convergence unadjustable after after repair
My jvc av48wp74 is having horizontal red convergence problems. this is after replacing the ic stk392-110 chips with stk392-180's and the 2.2 ohm resistors.when first turned on the picture was slightly out of focus, after auto convergence everything was perfect. when turned set off and on again the picture is double after trying to auto and manual converge found out that horizontal is unadjustable in the red and remains concaved up in the center from the bottom and down in the center from the top. Possible solutions? and how to test resistor in board?
  • jacques2001 May 11, 2010
    Hello. In my board I found that the resistors of 150 and 220 were perfect, less that 5% error. But the 1.5ohms readed 1.9, the 1.8ohms read 2.3, the one of 2.2ohms read 2.5. Do you think that this variations will cause problems ? tks.
  • JVC Master
  • 8,617 Answers
You have to lift one side of the resistor from circuit in order to measure resistance otherwise a open resistor will not read open as you will be reading the resistance from the surrounding circuit. Always lift one side of a resistor out of circuit when testing with a ohms meter.
Posted on Jun 06, 2008
Tv has started making red ghosts that go 2 the right of the screen, what is this problem?
Thats a convergence issue which is common for all rear projection models. The AV48WP74 - AV65WP74 convergence repair kit from www.tvrepairworld.com will usually solve convergence issues. The kit contains both ICs and the associated resistors and the CD with repair instructions.
Sep 15, 2011 | JVC AV-65WP74 Rear Projection Television
I have a jvc model av-65wp74. my green convergnece wont align at all
Convergence ICs and resistors need replacement. Very common issue. The AV48WP74 -AV65WP74 convergence repair kit from www.tvrepairworld.com has the 2 ICs and associated resistors plus the CD with repair instructions.
Aug 16, 2011 | JVC AV-65WP74 Rear Projection Television
AV-56WP74 the convergence is off. blue is way out!
You will need to replace the Convergence ICs and resistors you can get the JVC repair kit called the AV48WP74-65WP74 convergence repair kit from www.tvrepairworld.com which contains the ICs , resistors and the CD with instructions,
Sep 23, 2010 | JVC AV-56WP74 56" Rear Projection...
THE VERTICAL AND HORIZONTAL COLORS DO NOT LINE UP.IT KIND OF LOOKS LIKE THE PICTURE IS IN 3D.
Thats caused by failed convergence ICs and feed resistors. You can get the JVC repair kit called the AV48WP74 convergence repair kit from www.tvrepairworld.com which contains the ICs , resistors and the CD with repair instructions.
Sep 12, 2010 | JVC AV-48WP74 48" Rear Projection...
Have a jvc i-art pro 56" from 2003 have a red halo surrounding images. what can I do to fix this and where do I acquire the parts? Thanks
Thats aconvergence failure. You can get the AV48WP74 convergence repair kit from www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions for the repair.
Jul 10, 2010 | JVC AV-56WP74 56" Rear Projection...
Red line on screen
Install the JVC repair kit called AV48wp74 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and step by step instructions.
Jun 29, 2010 | JVC AV-48WP74 48" Rear Projection...
Double images with one of the images being red.
very common problem caused by failure of the convergence ICs. You can get the AV48WP74 convergence repair kit from www.tvrepairworld.com which has the ICs, Resistors and also contains the instructions on CD
May 12, 2010 | JVC AV-56WP74 56" Rear Projection...
I have double vision on the screen tried to do the automatic conversion but the red and blue wont align in the middle. I dont have the right remote to do it manually what can I do
A convergence repair kit will need to be installed. your model uses the AV48WP74 - AV65WP74 convergence repair kit. You can get it at www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions.
Dec 13, 2009 | JVC AV-56WP74 56" Rear Projection...
The TV has just started a red/green problem. The picture is double in the top and bottom of the screen with one image red and the other green.
you need to install a convergence repair kit. The AV48WP74-AV65wp74 convergence repair kit from www.tvrepairworld.com has the parts and the CD with instructions.
Dec 11, 2009 | JVC AV-65WP74 Rear Projection Television
Convergence problem for my JVC Av48wp74
replace the convergence amp IC that is the defective parts!
Oct 02, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
191 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
