Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
I have to go online about every 48 hours to change the channel on my route, because my computer loses its connection even tho i have an excellent signal
  • sagar patra May 11, 2010
    PLEZE CHANGED IT
  • 68 Answers
You should call the tech support of your internet provider
Posted on Jun 23, 2008
How do I get my tablet to sync up with my router, even tho it is giving me a message that there is an excellent connection available on my router, using the MEP router code?
If you tell your tablet to connect to your router (click on your router) It should then ask ask for the pass phrase or password you will find this on your route usually on a sticker on the bottom enter this and it should connect you
Mar 03, 2015 | Proscan 7-Inch Android Internet Tablet,...
Car doesn't seem to get enough gas to engine
Have you done a tune lately on the car?
I would also suspect a fuel pump problem is you've done a tune up recently.
Jul 11, 2008 | 1994 Hyundai Excel
I have to get hooked to the internet to get my channel changed about every 48 hours. i have used every channel at least once. but, my signal strength is always excellent.
On your desktop PC, connected to the router via an Ethernet cable, open your internet browser (Internet Explorer?) and type in 192.168.2.1 into the address field.
That will open the router's configuration page for you.
Click Login, Submit {should not related to your problem but if you have left the default password as blank, don't; set one of your own up a.s.a.p.)
On the left hand panel under the "Wireless" section;
should be an entry for "Channel"; if this is set to Auto, leave it as it means the router can change channels automatically.
If not, it should allow you to select Channel numbers 1 - 13 inclusive; choose one.
there should also be a field called "Protected Mode"; set that to "On".
hope this will help
Jun 07, 2008 | Belkin Computers & Internet
Unable to access internet tho my wife is on her laptop right next to me!
Dear penny alden
You may have to put an ip and dns,check your wife's ip settings and do the same in your lap with changing last number in ip address.
Best Regards
Mazagange
Mar 29, 2013 | Dell Inspiron Mini 10 Notebook
My wifi doesn't work.
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Oct 08, 2012 | Computers & Internet
My Laptop (gateway nv54) are approximatly 10m from my router tew-652brp. and the signal are just "good" . how can i get a excellent signal. thanks
You would probably need to be closer than 10M from the router to get excellent.
Honestly I am not even that far from my neighbors connection, and they don't always show up as excellent.
Don't worry, you are likely still getting 48-56MB/s connection to a router which is connected to a modem that probably doesn't even have a 10M connection to the internet.
In other words, even if your connection was excellent with a side of turbocharged, your internet wouldn't be any faster than it is now.
The only thing affected at this point in computer to computer file transfer speeds and such within your own local network.
However, one tip that might help is to switch from channel 11 if you're on it (the usual default) to channel 6. This is done in the router settings, not the PC.
Don't forget, TrendNET although I use a bunch of their stuff, is pretty much the BIC of the computer world. Ya, it'll do what it's meant to, but there's so many other brands that do it so much better - the trade off is almost everything else is quite a bit more expensive!
So, short of parabolic reflectors or antennas that cost as much as the router itself, there's not much you can, or even need to do - it's a bit of a non-issue.
If you'd like to discuss parabolic reflectors or external antennas though, I'd be glad to.
I have a couple external antennas I just love!
Mar 19, 2011 | Trendnet TEW652BRP 300 Mbps WiFi N router...
Can't get online, even though computer says connected
As the router is working and connected to the internet - then its probably and issue with the wireless setup on router or your PC
1) remove any wireless profiles on your PC read here - how to do that http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm then when reconnect it will ask for the key again 2) A firewall maybe blocking your access - disable any firewalls 3) Remove the wireless security if enabled in the router and see if you can connect - if this is the only wireless device connecting - it may interference try also changing the wireless channel in the router - use 1 or 6 or 11
Mar 14, 2010 | D-Link Computers & Internet
I have a 2 Wire network adapter on my desktop pc
If you can see many Wi-Fi nets at your area, try changing the settings especialy the channel transmition for your net.
Stelios.
Feb 21, 2010 | Computers & Internet
Wireless Network Connection constantly reading low/vlow/no signal
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
Jan 04, 2010 | Computers & Internet
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
18 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
