Question about Kenwood XD-655 CD Shelf System
When i turn on , the display is" PROTECT " KENWOOD XDA55
    Problem Solver:
  • 19 Answers
Make sure the speaker wires aren't shorted anywhere.....a short normally activates protect mode on most stereo systems.
Posted on Oct 28, 2010
SOURCE:
I have Kenwood kdc- mp343 it displays protect then what happens?
Disconnect all speakers from unit. Turn on. If still in protect then unit is damaged and needs repair. If not then reconnect 1 speaker at a time until it goes into protect. That speaker is either shorted or wiring is shorted.
Oct 30, 2016 | Kenwood Car Audio & Video
Kenwood kdc-mp442u protect mode came
First of all , your Kenwood shows only Protect on the display when your speakerwires are conflicting with each other , but when you cannot find the problem there....
disconnect them one by one to see wich speaker in your car is conflicting (shortcuts).
Replace that speaker and your kenwood will work just fine.
I had the same problem here with a brand new Clarion speaker .
Oct 08, 2010 | Kenwood KDC-MP442U
My stereo says" protect" everytime i turn it on. can't get anything else.
Hello grammagrisbo, hi your Kenwood head units will show "protect" when there's a problem with the speaker outputs so check to see if the impedance load meets your radio, 8ohms or 4 ohms?. having parallel two speakers on a single channel may cause this dilemma. This might also mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back to normal, the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do something to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. power it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker only. Turn it on again and see if it will displays "protect" message.
If the radio works with one speaker connected, connect the other speaker to the second channel, you may have now the idea where the problem begun, you will identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that channel.
If it displays "protect" with a single speaker connected, then disconnect that one and try the other one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit.
Aug 31, 2010 | Kenwood Car Audio & Video
When ever i turn on my engine which means my kenwood kdc237 shud come on its just flashing protect protect protect no matter wot i press nothig happens need help cant do without music.
If protect is coming up on the display, it means the system is detecting a short somewhere on one of the speakers and so is turning the amp off to avoid damage.
Check all the connections at the back of the amp to ensure they are not shorting, and at the back of each speaker, if nothing is found there, check each wire for damage, or a bare wire touching the body of the car
Jan 20, 2010 | Kenwood KDC237SA CD Player
MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
Dec 09, 2009 | Kenwood KDC-319 CD Player
Protect apears in display of my carradio Kenwood KDC 3034
I did not resolve my problem and I defenitly am not going to pay anything to you to resolve it. So if you have the resolution to my problem tell me or do not bother to write to my email adres anymore. Thanks for your answer.
Jun 22, 2009 | Kenwood Car Audio & Video
Is remote necessary to reset code on kenwood kdc 319
my CD player is Kenwood KDC-W3041 displayed protect and i can't turn it on. what can i do for that?
Mar 29, 2009 | Kenwood KDC-319 CD Player
"PROTECT" is displayed on the car stereo when turned on
This is really easy to fix. Look on the face plate for a REALLY small hole. Put the tip of a pen in the hole and it should work. This usually means the stereo isn't wired properly so if the PROTECT keeps coming on after you've re-set it, take it to a dealer. To make sure you're everything is in properly. Hope this helps...
Jan 26, 2009 | Kenwood KDC-MP228 CD Player
How to get a display ''protect off of my car audio?
one of your speaker wires to the internal amp is shorted. turn power off and make sure they are not touching metal or each other and then hit reset again. if this doesn't help your power ic may be fried inside the stereo or a speaker is shorted.
Nov 29, 2008 | Kenwood KDC-MP435U CD Player
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Kenwood XD-655 CD Shelf System Logo
450 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
