Question about Toastmaster 1142 Bread Maker
Mixing After the first cycle (the machines first beep), the mixture does not turn into a ball. It is mixed up a bit but not in a ball like the book says it should be at this point. I checked the paddle when the machine was empty and it does rotate. All in all, it is not mixing properly. Any ideas?
Your drive belt may be slipping
Posted on Jun 27, 2008
How do I adjust my breadmaker for high altitude baking?
Hello, you dont adjust the machine, you adjust the ingredients. what you want is that perfect ball during the mixing cycle, not too sticky but a perfect bouncing rolling ball.
Mar 15, 2015 | Breadman TR444 Bread Maker
Why do all functions work but the mixture is not mixing?
Check to be sure the mixing paddle is properly affixed to the mixing post.
If the motor is turming and the mixing paddle is properly seated on the post inside the mixing bowl but it still does not turn, be sure the post can turn freely and is ont stuck in place. You may need to replace the mixing bowl.
If the motor is not turning you will probably need to seek out a repair service.
Mar 03, 2015 | Kitchen Appliances - Others
Welbilt bread machine kneading wont start.making ticking sound
some bread machines warm the ingredients before any mixing starts. If your breamachine doesn't start mixing within 1/2 hour then you DO have a problem. Give it a half hour before you assume it is broken.
Dec 10, 2013 | Welbilt ABM3500 Bread Maker
Washer beeps as if unbalanced when in rince cycle and water is leaking a bit from somewhere, clothes are still damp. fisher and paykel
if it's leaking, take it somewhere to get checked, water and electronics don't end up mixing in a cheap way! the leak could be the pump or main seal. the unbalanced thing can be due to spring failure.
Aug 15, 2013 | Fisher and Paykel GWL11 Top Load Washer
What is the mixing ratio for the fuel(fuel+oil)
Hi marius65..
Use the normal mixture for 2 cycle engines
50 to 1 mixture...1 pint of 2 cycle oil to 6 gallons of gasoline
Please rate me
Bud
Oct 03, 2012 | Ryobi 30cc 17" String Trimmer Zrry30530...
What kind of gas
Regular unleaded gas mixed with 2 cycle oil. (You need to check your model for mixture ratio but 30:1 (thirty parts gas to one part oil mix) is usually a good place to start) You can find mixing instructions on the back of the 2 cycle oil container
Dec 08, 2010 | Garden
What is the gas/oil mixture for the poulan wild thing chain saw please?
Use a quality 2-cycle air-cooled engine oil. Poulan recommends a good quality 2-cycle air-cooled oil designed to be mixed at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 onces of oil with 1 gallon of unleaded gasoline). When mixing fuel, follow the instructions printed on the container. Always read and follow the safety rules relating to fuel before fueling your unit.. Be Safe!
Sep 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the fuel oil mixture for a homelite gas trimmer model ut20779
Hi a safe fuel mix is 25:1 but most homelites run a mix of 32:1 either one should be ok
Jul 03, 2009 | Garden
My Black & Decker B900SC bread machine doesn't mix properly
Have you tried adding a bit more water to your mix? It sounds as if your dough is too dry. Sometimes, no matter how exact you follow directions, you have to compensate for variables of the machine. I have a similar problem with some of my bread mixes if I do not add an extra tbsp or two of water.
May 13, 2009 | Kitchen Appliances - Others
Addidng ingredents
Sorry, I don't know too much about breadmakers, but generally speaking, you add ingredients that you want to remain solid later into the mixture. If you add them before the dough is dough-y, then they'll get crushed.
May 27, 2008 | Sunbeam 5891 Bread Maker
Toastmaster 1142 Bread Maker Logo
134 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
