Question about HP DeskJet 6122 InkJet Printer
Interfacing my HP 6122 with my WiFi laptop
How can I get my WiFi laptop to interface with my HP 6122 in order to print out documents?
    Sergeant:
  • 352 Answers
Hp sells wireless adapter interfaces for its printer. Check out their site and what they have to offer.
anaanymous
Posted on Oct 13, 2008
How do I do the interfacing on simplitiy pattern 4149
The interfacing is just an "echo" of the pattern part, ie collar, and adds body to the fabric piece. There are fusible and sew-in interfacing. If it's sew-in, you just lay the fabric and interfacing together and sew as one piece.
When and How to Use Interfacing Sewing Tutorial on Craftsy
Different types of interfacing and when to use them So Sew Easy
Interfacing Choosing the Right Type and Weight
Dec 16, 2016 | Sewing Machines
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
Server 2008 drivers for HP deskjet 6122
"Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with many Windows systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch.
Jul 04, 2012 | HP DeskJet 6122 InkJet Printer
I want to print in grayscale
Try a different driver. "Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). All these drivers seem to be the same print quality in my systems.
Feb 03, 2012 | HP DeskJet 6122 InkJet Printer
I have an HP Deskjet 6122. Cannot get documents
Your printer needs some manual servicing.
It's advised that you leave it for a qualified technician to do that.
From the problem you described, the encoder sensor may be causing this problem.
Mar 10, 2010 | HP DeskJet 6122 InkJet Printer
Can i install the HP Deskjet 6122 on a brandnew HP Laptop with vista OS?
"Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Oct 10, 2009 | HP DeskJet 6122 InkJet Printer
Interfacing HP Deskjet 6122 to laptop
one u cant because this pesific printer unfortunatly isnt wifi... :'(
i checked and second not many are like that and it would be great to have one like that though
Jun 22, 2008 | HP DeskJet 6122 InkJet Printer
HP DeskJet 6122 InkJet Printer Logo
94 people viewed this question
Ben Johnson
