Question about Sewing Machines
My thread keeps om breaking i have juki lu1508n please help
When i sew on the machine the thread always breaks.
  • sewel Jun 06, 2008
    I have a tacsew blind hemmer. It either won't catch a stitch or the thread. I have used all sizes gueterman thread & serger thread. I have changed to 3 different size needles. HELP!!!!!!!!!!!! FRUSTATED
Try extending the looper just a hair. loosen the screw and pull past the stop just a fraction.
Posted on Jun 07, 2008
Why does my machine break the thread a lot? A juki cp 130
tension too tight or incorrect threading, or bad thread.
Mar 13, 2017 | Juki Sewing Machines
I have a Juki TL98E and when I got it forgot to put the presser foot down and obviously the needle broke several times. Now the thread keeps breaking. Thoughts?
Remove all the thread from the machine. Thoroughly check that there are no stray threads or lint stuck anywhere. Oil your machine per the instructions.
Make sure you are using a brand new needle.
ALWAYS RAISE the presser foot and rethread the machine. Verify the thread path is correct. Check that the bobbin is installed and threaded correctly.
Set the tension to the midway point. Pull the bobbin thread to the top of the fabric. Gently hold the thread tails while you take a couple of slow stitches.
If it is still not sewing correctly, it's quite possible the timing is off (which is common when a needle breaks). You'll probably need to take it for service.
Oct 27, 2016 | Juki Sewing Machines
Juki TL2200
Check thread routing
Jul 20, 2016 | Juki Sewing Machines
Why does my thread keeps breaking when backstitch on Juki DNU-1541?
you didn't say if the top thread was breaking or the bobbin thread
here are some suggestions
May 04, 2014 | Juki Sewing Machines
Thread keeps breaking
Hai, I think your thread very old or thick. Please putting some drop oil in thread. If your cloth lighter, you use small size needle and new cotton or silk thread.
Mar 13, 2014 | Juki Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Oct 08, 2012 | Juki Sewing Machines
Juki skipping stitches
completely un-thread the machine and rethread it in this order.
Upper Looper, Lower looper, right needle Left needle. It has to be in that order ALWAYS. If you break a thread... un thread and start the threading process again.
If rethreading doesn't work... change the needle that is skipping.
Good luck
Aug 16, 2012 | Juki MO6714 Mechanical Sewing Machine
Juki mo 2316 nEEDLE THREAD KEEPS BREAKING
I took my machine in to a place that fixes machines.
Thanks anyway!
Sep 09, 2009 | Sewing Machines
Thread keeps breaking on sewing machine
Probably just the needle. Try turning it 180 degrees
Aug 24, 2009 | Yamata FY700 Mechanical Sewing Machine
Sewing Machines Logo
230 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
