Question about Frigidaire FRS26R4A Side by Side Refrigerator
Door frame really hot to touch
When you open Frig door, you couldn't touch the frame with out getting burn and frig not cooling well. I removed the back cover the big round black tank in far left was hot enough to fry an egg. I noticed the fan was not spining at all and I assume this fan kicks on and off with some sought of thermal switch. I disconnect the fan and put a multimeter on the power side and was getting normal voltage (115-120), then I did an ohm check on the fan it self on the two power leads and it read open (shorted) and so I assume this is why the frig is overheating. LIke a car radiator, it the coil and condensor I suspect need the fan to draw air to assist in cooling. I am only guessing here, any help would be appreciated as I plan on getting new fan, but don't know how to remove it.
Had the same problem..door frame was hot to touch etc..
we checked the fan and there was dead mouse stuck in it..
my husband removed the mouse and luckily the fan kicked right back on
Posted on Jun 08, 2008
  • 770 Answers
Also clean the coils underneath the unit as far as the fan (condenser ) you can put a house fan on the back blowing to cool the compresser until you get a replacement. That fan runs anytime the compresser runs
Posted on Jun 06, 2008
I have a ge refig side by side the # is 62D581P016 the door frame where the gaskets are located gets hot to the touch. We have cleaned the back under the frig and the fan is running, however, it is st
Most modern refrigerators have heaters around the gasket to keep frost and condensation from forming. What you're seeing may be normal.
Sep 09, 2014 | Refrigerators
A bad smell (like a chemical) was coming from the frig but it was still working fine. Repairman couldn't find anything - other than saying it smelled like burnt wiring. Then a few days later, the...
There is a stile heater around the door opening and sounds like it shorted out. This would be the smell you noticed. The plastic door trim should have felt exceptionally warm to the touch
Aug 01, 2011 | Turbo Air MSR-49NM Refrigerator Commercial
Bulbs burning and causing frig to get hot.
I need the model number you may have a short and lights are reaming on while door is closed. This sounds like a recall or fire hazard Unplug let the area cool remove the bulbs or risk property damage until confirmed what model you have Sea Breeze
Dec 13, 2009 | GE Refrigerators
Hot refrigerator door jamb
This may be part of your energy saver. The opening around the door will be warm, but not hot to touch, to prevent condensation from forming during humid weather. If you have a switch in the frig marked energy saver, switch it to off, check to see if the frame cools. This feature is automatic in some makes and models and there isn't a control. If no condensation forms when it is switched off, it is not necessary to run the energy saver. Check the owners manual, if one is available, for information on your particular model.
Jul 11, 2009 | Whirlpool GC5SHEXNS Side by Side...
LG Fridge gets very hot on panel ( by the door)
pull frig out from wall and take back off lower part and check the cond motor to make sure it is blowing and chances are it isn't so it will need to be replace / if so you can set a small fan behind to blow on compressor and coils to keep it cool till you can replace it / larry
Dec 01, 2008 | LG Refrigerators
Light not going out in viking frig when door is closed
you have a micro switch at the top of door by the door hinge.must remove top vent cover to access. i've found that if the screws (2 or 3 phillips ) get loose the door is not aligned to open and close the light switch . or maybe the switch itself has failed
Nov 26, 2008 | Viking 24 in. Professional Series VUD141...
I have a side beside whirlpool refrigerator/freezer. today I noticed the strip between the frig and freezer was very hot and coil under frig are almost too hot to touch. It has been this way since about...
no danger of fire, they(Whirlpool) run a copper heat tube through the center mullion of frig, to cut down on amount of undesirable condensation that may build up between doors, reason for extra heat can be from leaving door open too long, perhaps the coils under the frig need to be vacuumed,
Oct 12, 2008 | Whirlpool Refrigerators
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Any thoughts?
Any noises from frig at all??? cicking humming???pull the unit out and remove back cover. Is the compressor(football)size motor in back hot to touch??Lights are on in frig right?
Feb 26, 2008 | Refrigerators
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
395 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
