Question about HP DeskJet F380 All-In-One Printer
Paper tray Even when the paper tray contains paper, it reads: No paper and indication "E' is on. On re-insertion of paper into the tray also the sign "E" remains.
  • Anonymous Jun 13, 2008
    When I try to print NO PAPER ERROR comes up on the screen and it refuses to print!! even though is full of carefully installed paper HELP!
    Problem Solver:
  • 14 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=ca&lc=en&dlc=en&product=1128296
Posted on Jun 12, 2008
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Printer screen shows " Out
Hi tpuette
Be sure that the paper in the paper try rests within the guides. Also, ensure the that paper try closes properly and is not loose. Be careful also with the amount of paper you load into the printer, don't load too much into the tray or it may cause a paper jam.
Once the paper is loaded the printer may want you to confirm this by pressing a button, this will usually be a button with "OK", "Yes" or "Enter" printed on it. Check the little screen on your printer for such a message.
Hope this helps :)
May 15, 2011 | HP PS C4780 All in One InkJet Printer
Error 077-900, what does that mean?
this error indicate paper jam at registration unit, to clean:
1. remove paper tray
2. open fron cover
3. remove jammed paper gently without tearing it
4. check if there are any creased paper sheets in tray, remove if any
5. check paper path if free from debris and any leftover paper tears/fragments
6. close front cover
7. insert back paper tray
If this advice did not solve your problem, please do not hesitate to follow this thread and I will forward further procedure how to check sensor and path.
Aug 12, 2010 | Dell 5100cn Laser Printer
Feed jam
1) Be sure the paper tray is inserted all the way in.
2) Be sure you're using the right size of paper (width, length and thickness; paper that is too thick may jam a laser printer if it is not configured properly)
3) Be sure you're using the correct TYPE of paper. Paper designed for ink-jets sometimes produce paper jams on laser printers.
4) If the paper was jammed before, you may have a small piece of paper jammed in the printer rollers. Open the printer and very carefully look for small pieces of paper on the rollers and all the paper paths.
5) Also, some printers are very picky about how much paper you have in your paper trays. Place enough paper on the paper trays so that it is about 3/4 full, no more, no less.
6) The paper rollers that pick up the paper may be dirty with dust. Use a q-tip and 2 drops of rubbing alcohol to wipe the rollers clean. Rotate the rollers with your fingers to be sure that all the surface of the rollers are wiped clean. Be sure to use 91 % rubbing alcohol; carefully read the label of the alcohol and use the one that DOES NOT contain anything except rubbing or isopropyl alcohol and water, no glycerin or any other additives. Wait at least 1 hr before using the printer again to be sure that the alcohol has completely evaportaed .
Please, report back if you need further assistance.
Mar 31, 2010 | Samsung CLP 315 Laser Printer
Does not recognise the loaded paper
I also had this problem. Had no idea what the problem was. The printer would not print regardless of when paper was put in the upper tray or the side tray. I then read the instruction manual carefully and realized the bottom green light on my printer was lit for the *BOTTOM* tray... I just pushed that button and the light shifted to the top tray and now it works like a charm! :-)
Feb 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
My photosmart C3150 printer keeps feeding many sheets of paper when it goes to print. This causes a paper jam. How do I get it to only take a single sheet?
Try cleaning the rollers with purified water. See instructions here. Also make sure you fan the paper before loading, try flipping it upside down, and see here. If you have no luck, try another brand of paper, or loading more or fewer sheets...
Good luck, that's a frustrating problem...
Jul 30, 2009 | Office Equipment & Supplies
Printing problem with HP 2015 Laserjet Printer
If you have an adjustable paper tray, make sure that the tray is set for the right size paper. Also, you may have some type of sensor in or around the printer tray that tells the computer when the paper tray is empty. Sometimes these sensors get stuck and you have to free them up (very gentley).
Hope that helps - Ghost
Oct 27, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 2430dtn - "Tray 2 open or empty"
1-Is the paper set correctly in the tray? if you have Letter paper in it make sure the guides are snug against it
2-Check the lever inside the tray, remove the tray and look at the tires there should be a lever that you ca move freely that is the paper sensor
Oct 10, 2008 | HP LaserJet 2430dtn Printer
Paper not grabbing
There are two possible solutions for this problem.
Usually it is due to the pickup roller wearing or becoming contaminated with toner or paper dust.
Simple solution, clean the pickup roller, the best thing for this is WD40, put a very small amount on a clean cloth and wipe the roller underneath the printer. Use a clean dry piece of cloth to wipe off any residue.
More complicated solution, remove the roller and reposition, you will need two small flat-bladed screwdrivers to pry apart the retaining clips, remove the roller, a tight squeeze beneath the laser housing, reposition and clean as above then refit the roller. You should find that the paper is picked up cleanly once again.
I hope this helps,
Jan 18, 2008 | Samsung CLP 300 Laser Printer
HP DeskJet F380 All-In-One Printer Logo
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
