No dial tone, usb fash drives dont reconize
Ran complete virus scan, also ran windows defender,Ad-aware, and registry cleaners
  • 1 more comment
  • pitman3 Jun 10, 2008
    I opened up laptop and modem wire was barely pluged on so i plugged it on securely and modem works now . Thanks
    I still cannot get usb flash drives to work on this laptop with vista, I use them on multiple computers with xp.
  • pitman3 Jun 26, 2008
    I tried everything suggested and then I added a pcmcia cardbus adapter, usb devices work fine through this adapter. thanks for all the help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Did you try AVG sometimes some of the orther software or i call dormit mcfee or norton doesn't seem to catch all the virus that are hidding behind your windows applications try it and get back to me lala linda
Posted on Jun 07, 2008
  • Priscilla mcdaniel Jun 11, 2008
    dearest pitman i am glad you got your wireless working !usb prombelms are common with vista not reconizeing them also xp
    It is a pain process that you have to go threw to get them to work unhook them uninstall them (turn of your pc) make sure you have them completely uninstalled and then reboot computer with the usb item installed in the ports then if it doesn't reconize them you have to go to add new hardware in your control panel,insert disc and run for that item ... Now if this doesn't work it mite be the case that the item your installing is not compatable with vista ...
    then you mite try the company that you bought it from and they mite have a new download you can get for it I hope this helps lala linda
Why does System Mechanic Pro 14 freeze before it totally completes optimizing disc drive. May be 30% or 70%. Have had running 6 hrs. and still not complete and has not advanced for 2 hours. Sounds as...
I would cancel it, then run CCleaner, then run SMP14 again (if you want to)
I have found CCleaner to be the best Registry and Temporary File cleaner. It has a free version, which is what I use on each Windows Account, every few months.
Configuring:
On the Cleaner/Windows tab, I uncheck "Thumbnail Cache".
On the Cleaner/Applications Tab, I uncheck SUPERAntiSpyware, MalwareBytes, Windows Defender, MS Management Console, and MS Search (if they are present).
Running:
Start CCleaner.
Cleaner - Analyze, then Run Cleaner (click OK)
Registry - Scan for Issues, then Fix selected issues (Yes, Save, Fix All Selected Issues, OK, Close)(Repeat the Registry process until no more issues are found, or the same ones are found each time)
Click the red X to close Ccleaner.
Good luck.
G
Aug 05, 2014 | Iolo Technologies System Mechanic...
Fash drive virus
Insert your USB drive in the appropriate USB slot in your computer.
If the Autoplay dialog box appears, select "Take No Action" and click the "OK" button.
Launch your anti-virus program, such as AVG Antivirus or Anti Malware.
Select the USB drive for the program to scan.
Click the "Start Scan" button or option.
Open the scan history for the USB drive when the scan is complete to see a list of viruses and warnings identified by the antivirus software.
If desired, select the options to "Heal All Infected Files" or "Move the Infected Files to the Virus Vault" to ensure these files are quarantined from your system.
Highlight each infected file in the scan history.
Write down the file name of each infected file identified on the USB drive.
Minimize the application's window.
Select "Run" from the Windows "Start" menu. In the Run window, type "e:/" at the command prompt to switch to your USB drive (or type the drive letter for your USB drive).
Press the Enter key.
Type "attrib -s -h -r -a *.*" at the command prompt to remove the system, hidden, read-only and archive file attributes.
Type "del ####.+++" where "####" is the file name of the infected file and "+++" is the file extension, at the command prompt line.
For example, "del terriblevirus.exe" will specifically delete the Terrible Virus executable file. Repeat for each infected file on your list identified.
Close the command prompt window; that is, exit the Run utility.
Maximize the window for your anti-virus program (which is still open) and repeat Steps until no virus is detected on your USB drive.
Exit the anti-virus application.
or Click start click on my computer you should see your usb drive right click then select format.
another way is to control panel administrative tools computer management disk management Right Click on your drive select format
Sep 25, 2012 | Kingston 1 GB microSD Card with USB 20...
Universal serial bus virus delete
Start ->run -> type cmd -> type attrib -r -a -s -h *.* and press enter.
What this basically does is removes the read only, archive, system and hidden file attributes on the files so that the virus or the container of virus will be shown.
Within the command prompt you will run the delete command to delete these suspicious files as the are shown up, example type del Autorun.inf or del New Folder.exe.
When you have finished doing that unplug your flash drive, update your anti-virus and scan your entire system.
Last but not least plug back your flashdrive into your computer and scan it with your anti-virus.
Viruses on flash drives are usually spread because windows has the Autorun feature set automatically run by default and this needs to be disabled.
Here is the easiest and fastest way by far to disable the autorun feature.
Download Disable_autorun.reg registry key.
Click Save to your computer ->Rigt click on file -> click run
Click Yes to confirm addition to the registry
http://www.majorgeeks.com/Kingsoft_Free_Antivirus_d6512.html
Kingsoft provide a complete and powerful security solution for personal users. Kingsoft Free Cloud Antivirus defends against viruses, spywares and malwares real-time.
Detect all type of virus and threats with multiple guards.
It include USB device protection, disk cleaner, History cleaner, process supervisor, LSP repair tools and system repair.
hope this helps
Sep 09, 2012 | Targus Acp45us1 Docking Station. Docking...
How+to+delete+remove+virus+manually
hi,
shut off system restore in system properties in control panel and then do a boot time scan of your antivirus. somewhere in your antivirus settings will be a boot time scan, which means the antivirus will run before windows starts, turn that on then reboot, let the antivirus clean it up. restart . turn restore back on, run checkdisk by right clicking your c drive in my computer navigate further untill you find checkdisk and run that to make sure your registry is OK.. download ad aware and spybot over up and above your antivirus and dont fileshare unless you know how to check the files before you download them..
jm
Apr 30, 2011 | Computers & Internet
Message " Windows cannot find "AdmINisTRAtoR.Exe"
Its looking the registry error in ur system so do a registry repair scan with Intel software partner Reg In Out registry cleaner
Sep 01, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Winplayer.exe and autorun.inf virus
you probably have the virus on your registry and that is a tough one. it depends on the type of virus you have, it may not allow you to install an anti-virus, but you can give it a try. download ad-ware or malwarebytes from the internet, the free version and enable all the settings. start with the malwarebytes its good for problems like this and see if it can get the virus out.
Jun 23, 2009 | Microsoft Windows XP Professional SP2
My Laptop is suddenly taking 15 minutes to load up after turning
clean the pc up to speed it up a little, download ccleaner and install it, run the cleaner and delete all the files it finds, then clean the registry and fix the issues found, if it asks you to save the changes to the registry click yes and fix do this a couple of times so no issues are found.
If the pc is still slow after this clean then the issue is either memory or the operating system is degrading.
http://www.filehippo.com/download_ccleaner/
good luck
Jan 26, 2009 | Acer Aspire 5100 Notebook
IE7 Home Page hijacked by a Dell advertising page
This is some advice I found after researching on Web: If I were you, I would get SpyBot Search And Destroy, and Ad-Aware 6 They are both Free award winning programs. But GET BOTH IF I WERE YOU. [Ad-aware is better in the sense that it finds more things and is updated alot more often] But Spybot is able to find a few things that Ad-aware Cant also. So, Get those 2 programs, and Update them. Be sure to customize Ad-Aware's Scanning settings to make sure it scans everything possible.
I would suggest scanning with Ad-Aware First, then find those extra few registry keys that Ad-aware couldnt detect, with SpyBot. Also, A VERY good program is SpySweeper. That has ALOT of definitions.
Dec 31, 2008 | Computers & Internet
Weird addressbar flipping
The Yahoo Software comes with Spyware & Adware; never seen AT&T Yahoo Antivirus detect any virus in my experience. Unfortunately you have to install the software to setup your DSL for the first time; after that it's worthless. I would scan your computer with Microsoft Windows Defender or Ad-Aware by Lavasoft; both are free tools and find many of the common infections. Moreover, it wouldn't hurt to pay for a McAfee or a Nortin Subscription for virus protection; I use McAfee because it doesn't lag my system. There is a free virus protection program called AVG Free which I'm told works good for the price.
Nov 28, 2008 | Acer Aspire 5100 Notebook
No mouse cursor visible on monitor
Could be spyware, virus or a failing hard drive.
Download Ad-Aware® SE Personal Edition, a free program that you can download at:
http://www.lavasoftusa.com/support/download/
Check for updates before running program. Then follow the directions here to do a full scan:
The following explains how to set Ad-aware's settings to perform a "Full Scan."
In Ad-aware click the Gear to go to the Settings area.
The following items should be on a green check, not on a red X.
Under the Scanning button:
Scan within archives
Under Memory & Registry, Check EVERYTHING
In Check Drives & Folders, make sure all of your hard drives are selected
Under the Advanced button, check ALL under Log detail level (this makes it easier for visitors to the Lavasoft Support Forums to see what options you have selected should you require assistance.)
Under the Tweak button...
Some of these may not be an available option, depending on your version of Ad-aware and your version of Windows. Do not be concerned if you cannot select a certain item.
In Scanning Engine:
Unload recognized processes during scanning
Include info about ignored objects in logfile, if detected in scan
Include basic Ad-aware settings in logfile
Include additional Ad-aware settings in logfile
Include used command line parameters in logfile
In Cleaning Engine:
XP/2000: Allow unloading explorer to unload shell extensions prior to deletion
Let Windows remove files in use at next reboot
UNCHECK: Automatically try to unregister objects prior to deletion
Click Proceed to save these settings. When you would like to perform a "Full Scan," switch the scan mode from SmartScan to Custom.
After running Ad-aware, you must reboot your computer. It may be necessary to run Ad-aware two or three times if you have a lot of spyware, rebooting each time in between.
Where it says,"In Ad-aware click the Gear to go to the Settings area", on the top of the Ad-aware window, there are 5 symbols, click on the one that looks like a gear.
Go to: http://sarc.com/ Scroll down and click on,"Free Online Virus and Security Check" Write down exactly anything it finds, then return to: http://sarc.com/ and do a search for what was found. Symantec usually has a removal tool and/or directions for removing. manually.
Regarding the Hard drive, check out what PCWorld offers at:
http://www.pcworld.com/howto/article/0,aid,105869,00.asp
Hope this helps!
Apr 11, 2008 | Computers & Internet
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
