Question about HP Pavilion dv6000z Notebook
Battery operation I have an HP6505 and it works perfect except that when the battery is fully charged and I unplug the adapter, the laptop locks up and will not respond to mouse, keyboard, control-alt-delete. As soon as I plug the charger back in, it operates perfectly again! Thank you for your help!!
  • Meph1234 May 11, 2010
    When the battery is half charged and you unplug it, does the same thing happen?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Sounds like to me your battery is shorting out and you need to replace it ,your battery is shorting and back feeding into mother board and u need to replace it ..and fast or it mite take out your whole system .... lala linda.
Posted on Jun 07, 2008
Battery charging but laptop won't work while plugged in
The purchased is sub standard. Get a replacement from the store. N.B the fujitsu charger will work for some
Time and damage your laptop because of the higher amp
Jan 27, 2013 | Toshiba Satellite Computers & Internet
My dell inspiron1750 is on idle, not charging the battaery
Is the battery fully charged? Is the battery dead? Shut down, unplug , remove battery, reseat battery, reboot. Will it boot on the battery only? If no replace battery.
Dec 23, 2012 | Dell Inspiron Computers & Internet
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
My computer works great except when I plug in the A/C adapter...the screen goes black. I unplug the adapter, the screen comes back. The adapter does charge my battery fully. Can you tell me how to fix? ...
Try using the 'increase brightness' buttons (usually accessible using the fn key and a key with a 'sun' or 'lightbulb'-symbol) on your laptop while the A/C adapter is plugged in. Some laptops remember the brightness levels in each state (battery and plugged in), and go to that brightness level whenever they're plugged in/unplugged.
Dec 13, 2009 | HP Pavilion zd8000 Notebook
My laptop is fully charged but then when i unplug the ac adapter it says 0% battery
This is a typical indication that the battery has failed & need to be replaced. In your case, the battery only holds a tiny charge. That's why when you unplug the AC adapter it says 0% battery.
Sep 20, 2009 | Gateway MD2614u Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Laptop not running on battery
try another power supply, they can have voltage problems and still have ample voltage to run the laptop but not fully charge the battery.
Apr 13, 2009 | Toshiba Satellite A75-S1253 Notebook
Dell d410 laptop won't charge battery charger doesn't like the ba
There's a problem with the motherboard.
I would say try a bios update, but I believe it requires both battery and power adapter to be present before it will flash the rom.
The above probably won't work but it's always good to try the easy stuff first.
More than likely you'll just have to replace the board.
If you have any more questions, feel free to ask.
Feb 24, 2009 | Dell Lattitude D600 W/XP Pr Notebook
New 6600 mAh battery won't charge
Is the AC adapter the original that came with the laptop or is it a replacement?
Check the label on the laptop (on the bottom of the laptop) for the voltage and current requirements.
Check voltage output of the adapter with a multimeter, this voltage should be slightly higher that the voltage than what is shown on the adapter's label because there is no load on the adapter.
It could be that the current (amps) that the adapter is delivering less power than the laptop's requirements, whilst it can power the laptop it may not be sufficient to charge the battery fully.
Try charging the battery overnight by shutting down the laptop but leaving it connected to the mains. Then boot up the laptop in the morning and check the battery's charge state. If the battery is at or near full capacity, then the problem is a (part) faulty adapter.
Jan 07, 2009 | Acer TravelMate 8200 Notebook
Dell Inspiron 9300 battery charging problem.
Darrell... read this
http://www.dellbatteryprogram.com/
Robert
Dec 19, 2008 | Dell Inspiron 9300 Notebook
HP Pavilion dv6000z Notebook Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
