Back to:
Tags:
Panasonic Lumix DMC-LZ2 Digital Camera
My lcd screen is black (by 5 users)
posted by lorik97882 on Jun 06, 2008
when i turn my camera on the lcd screen is black and takes blacxk pictures
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by joebailey66, posted on Jul 16, 2008
I have the same Issue, Black screen cant take photos! Please help
Comment by sstratton, posted on Jul 07, 2008
Camera has worked great but recently started having problems with the display. If I push the display button SOMETIMES I will get a display and be able to take a photo. Otherwise, the screen is black. I can review old pics but can't take new ones.
Comment by DinaBW, posted on Jun 24, 2008
The same thing is happening to me--I can look at old pictures, but the screen is black when I try to take new ones. It started out as black stipes on the occassional picture, then on every picture. Now I don't get anything.
Comment by danlawson, posted on Jun 23, 2008
I can view old photos on the screen fine but any new ones are black.
Provided by PANASONIC STAFF
Best Solution
posted on Jul 18, 2008
FixYa! (100)
AMRITH
STAFF
Rank:Master Master
Rating: 80%, 12 votes
Hi guys. If an LZ1/2 camera has a black screen, the most common problem is that the flex cable that comes from the CCD is loose in its connector. It is a simple problem to solve. I normally make shure the flex is fully inserted before locking the clip and then I use a small amount of contact adhesive to hold the clip on either side.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on my lcd screen is black:
I don't want to Accept this solution
Solution #2
posted on Jun 26, 2008
Helpful (85)
sakelliou
STAFF
Rank:Wiz Wiz
Rating: 82%, 51 votes
hi there guys, if the screen is black and the camera takes black pictures, then you should look if you are getting a on screen display on camera mode. if you are then i would say one of two things, either the shutter is not opening or the ccd( electronic imaging device) is not functioning. to check the shutter you should look into the lenses centre part and check for movement from the shutter to see if it is opening.
Thank You!
Can you Help with these Digital Cameras problems?
My Lumix DMC-TZ3 comes up with the message 'Memory card...
When I turn the camera on, a red light goes on, but i...
When I power on a message says " Please turn the...
ela nao quer entra e tb nao tira mais fotos e nao paparece...
I lost the cd for the computer so I can't watch my...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
