Question about Whirlpool Washing Machines
It Is Not Spining And The Clothes Are Coming Out Soaking
  • 5,911 Answers
If this is a TOP LOADING washer, and it fills, agitates, but does not spin or drain, the problem is usually associated with a defective lid switch. The following link gives you advice on how to diagnose and repair.
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If the washer fills, agitates, drains, but does not spin, the problem is usually attributed to a defective motor coupling. This link gives you advice on how to repair this problem.
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
Please read through the advice on the links thoroughly to determine which symptoms fit the problem you are having. If you cannot diagnose your problem from what I have given you, please post back and let me know. I hope this helps you.
If this is FRONT LOADING washer, please post back and let me know if any fault codes are being displayed on the operator console.
NOTE: Parts can be found at searspartsdirect.com. If you need assistance in locating parts, please post back with your COMPLETE model number and I'll assist you.
Please go to my profile and use the "Ask Me" feature for a quicker response to any of your questions.
Posted on Jun 06, 2008
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Door locked red sign comes off
Has it ever run right? Are the water valves on? Is the selection by buttons or a touchpad? If buttons, make sure each is on a selection, not half way or in between. If touch pad, see if there is a reset.
Nov 28, 2013 | Indesit Washing Machines
Water not spining out
CLOTHES ARE SOAKED BECAUSE YOUR WASHER IS NOT DRAINING THE WATER.....ONCE YOUR MACHINE HAS DRAINED ENOUGH WATER OUT IT SHOULD START SPINNING AGAIN
Apr 16, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
I have a magic chef 20 lb capacity heavy duty washer model W20HN3S serial ME851474 with spin problems. Clothes come out soaking wet. Can I replace a belt?
If your washer will wash (agitate) your clothes but does not spin well, you will need to replace the "thrust bearing" in the washer. The repair is simple and will only take you a short to do. Here is a link to the "thrust bearing kit" you will need.
Jan 07, 2011 | Chef Cooking Magic Chef Washing Machine...
I have a kenmore elite washing machine. it is not spining the clothes all the way. it is leaving the clothes soaking wet.what should i look at
Take the agitator apart by pulling off the softener cup and taking out the bolt, probably broken plastic DOGS. Ask your appliance parts guy for them.
Nov 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
The clothes are coming out soaking wet.
just cause pump moves doesnt mean its working
Jun 04, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Apr 18, 2009 | Washing Machines
Not spining like it should
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Jun 01, 2008 | Frigidaire GLTF1670A Front Load Washer
My wirlpool ultimate care 2
Try the following 3 steps : - Check that filter's machin is clean (in case it is not clean, it will prevent water outlet). - Step before spining start, there is a pump that should drived the water out the drum. You should hear pump's activity. In case you don't hear it, you should check that pump receive power, if there is no power-you have a problem with the timer, if it receive power- you should replace the pump. - Check that no water leak or drip to the drum when the machin dosen't work- In case water coming in, you have a problem with the inlet valve that can no longer completely shut off when the electricity is turned off to it. To fix this- You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! In case valve cleaning dosen't help, you should replace it. Good luck.
Apr 18, 2006 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal De
