DVD cleaning disc rejects almost immediately also, will not stay inside DVD to clean!!DVD cleaning disc rejects almost immediately also, will not stay inside DVD to clean!!
On the DVD player face, look for a small hole about the size of a paper clip wire. Push a paperclip or toothpick into the hole and see if the DVD opens up.
hey Sweet
sorry no! but you can order an orignal replacement remote from here www.remotes.com and that wikk fix your problem!
Please rate answer!
Thank You!
On the face of the DVD, look for a small hole that you can push a paper clip into. This should allow the DVD to eject. Check the DVD for dirt, dust and damage.
the flash was the fuse inside the set blowing it usually takes out one or two diodes in the power supply section but maybeyou got lucky and its only the fuse.
The DVD rejects immediately after insertion. Set up appears to be correct.
