Question about Nintendo Wii Console
Remote the handset has 4 blue lights flashing all the time on the wii remote and has new batteries
The problem where the lights would flash on and then go off happened to me also.
I pressed the 'sync' button on the wii remote and the red 'sync' button on the console at the same time for about 10 seconds. Let go of the buttons and then the lights should flash and light 1 on the remote came up!!!
Hope it works for all 'ya!
Posted on Jun 06, 2008
How do you connect a rock candy remote to Wii
Make sure you have fresh batteries in it. the little red button under the battery cover is the sync button. Push it and you should see the 4 blue lights flash on the remote. Push the sync button on the Wii (red button under the front flap) and wait a few seconds. The remote light should stop flashing and one of the lights should light, indicating which remote it is (1-4) Repeat as necessary or change the order of button pushing if it doesn't work the second time.
Mar 14, 2015 | ROCK Video Game Consoles & Games
Bought a new will remote but it doesn't work.
Check the battery levels. You can do this by pressing A. If all 4 lights flash on and off, your batteries are completely charged. 3 lights, 2 lights, and 1 light signify 3/4, 1/2, and 1/4 battery levels. If lights don't flash, replace/insert batteries.
If it's not working with your console, open up the battery cover and the flip lid on the front of the console. (If it's a Wii U, you don't need to open the flip lid.) In both places, there is a red button. (On Wii U, it's next to the flip lid.) Press both red buttons at the same time. (Your Wii will need to be powered on.) The Wii Remote will continuously flash lights until it either receives a sync signal or about a minute has passed; whichever comes first. If you've pressed the buttons and your remote is still flashing, press the button on the console again. Once the remote is synced, the flashing lights will turn into a single light; the placement of the light will vary depending on how many remotes are signed into the Wii.
*Note* Once your remote is synced, you simply need to press A to sign back in if your remote turns off.
If all of the above steps were followed, and your remote is still not functioning, contact the manufacturer. Brands such as Nintendo and Nyko are usually okay, but generics like GameStop aren't the best. It's often easiest to return it and buy a different brand.
Apr 29, 2014 | Nintendo Wii Console
Remotes won't connect. put in new batteries, tried pressing red button in side remotes, all 4 blue lights are flashing on both remotes
Hello kellyanne_ma,
The Wii must be searching for remotes before one will connect. If you are trying to connect controller #1 (meaning there are none connected) and it fails, there may be a problem with your Wii.
First, remove power from the Wii by unplugging it. Wait 30 seconds and then plug it back in. Once powered on and you see the health/safety information press and hold the red SYNC button on your Wii for 20 seconds.
Now press the Sync button on the controller and while the blue lights are flashing, press the Sync button on the Wii.
Hopefully, that will connect the controller! If it does not, you may need to contact Nintendo!
Jun 28, 2011 | Nintendo Wii Console
How do i resync my wii controler
follow the steps descrived below:
1.Turn on your Wii console. While on the HOME screen, press any button on the Wii Remote. If the 4 squares on the bottom remain dark, change the batteries (or for a rechargeable Wii Remote, place it on the charger for a while).
2.If the 4 squares blink blue, then stop, your Wii Remote is not synced. Press the 1 and 2 buttons at the same time. This should connect your Wii Remote if it's been synced before.
3.If your 4 squares still blink blue, then stop, these last steps will do the trick. First, on the front of the Wii console, just underneath the disc slot, there is a small panel that opens down. Open it and press the small red button.
4.Open the battery panel of your Wii Remote and press the small red button. Replace the battery panel and observe the blinking blue lights. If 3 stop blinking, and 1 remains lit blue, your Wii Remote is synced with your console.
Mar 03, 2010 | Nintendo Wii Console
On one of the wii controllers all i get is 4 blue lights flashing then nothing
The Wii-mote probably just needs to be synchronized to your Wii. Open the battery compartment on the back of your remote and open the front SD card slot on your Wii. Push the red SYNC button on the Wii and then the little red button on your Wii-moteand it should sync to your console.
Nov 10, 2009 | Nintendo Wii Remote Controller
Our wii remote wont turn on. we tried new batteries and all it does is the blue lights flashes and turns off. What is wrong and how can we fix it
Sounds like it's not synchronizing with the infrared bar. That might've come loose. Double check to make sure that's plugged into the Wii. If that's not connected the Wii Remote will not stay on because it's not connecting.
Oct 14, 2009 | Nintendo Wii Console
Wii remote will not turn on and the blue lights either
all you have to do is open the place where you put an sd card on your wii then open the battery cover on the wii remote and press the SYNC buttons at the same time and it WILL TURN ON trust me it works
Jun 26, 2009 | Nintendo Wii Console
Wii Problem, the remote
make sure a combination of the 4 blue lights at the bottom of the remote are on (but not flashing, mind you). if they're not, this means that your wii remote isn't connected to your nintendo wii system yet. if when you press a button and none of the lights turn on at all, this means that there are no batteries in your wii remote. if it flashes, this means its trying to connect to your wii system. you might have to troubleshoot this a little bit. try to aim it at the bar that recognizes the wii signal (a separate piece that comes with the wii system).
hope this helps ;-)
Apr 04, 2009 | Nintendo DS Lite
Wii Remote will not stay sync with console
Have you tried the following? If this doesn't work then pleae provide details on details such as the batterys you are using, number of remotes, etc.
The Wii maunual does not give clear instructions how to reset and sync your Wii remotes. I have found that from time to time my remotes will not sync, especially after they have changed 'order' a couple of times. It appears there is a bug in the code that keeps track of remote codes, and it has a limited buffer for the storage of remote ID's / order. Here are quick step by step instructions how to reset the remote list on the Wii console and re-sync your Wii remotes.
  1. Un-plug the power cord from the back of the console for 5 minutes (60 seconds should do, but leave it off longer to ensure all the power drains).
  2. Plug the Wii back in, and turn on the power button.
  3. Open the panel on the front of the Wii unit. You will see a Red button.
  4. Open the back panel of the Wii remote where the batteries are installed. Beneath the batteries is a small button.
  5. Press and release the small button. The Blue lights on the front of the remote begin to flash.
  6. Press the Red button on the front of the Wii unit.
  7. The Blue lights on the remote should stop flashing after a few seconds. Then one Blue light will remain representing player 1.
  8. Repeat for remote 2, 3 and 4.
Dec 28, 2008 | Nintendo Wii Console
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Sep 09, 2008 | Nintendo Wii Fit for Wii
Nintendo Wii Console Logo
231 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
