Dvd player plays with yellow tinge
I have a DVD player made by RED. Recently when I've played DVDs the colour has been distorted - the screen basically has a yellow tinge. I think anything that should be white is now yellow...
  • 476 Answers
If you are using a scart connection, check that it is plugged in fully & straight, also check for bent or missing pins.
Sounds like you have no green input.
Posted on Jun 10, 2008
New DVDs won't play without a loud buzzing sound, and a lot of glitching/jitter on the top half of the screen.
on the a/c adapter, (red yellow and white.. unplug your yellow connector and if that doesn't fix it, then plug it back in and unplug the white one.
Mar 23, 2014 | GoVideo DV2130 DVD Player/VCR
Dvd screen comes up on TV but dvd player says "disc error".
unplug the pwr cord from dvd for 5-10 min..plug back into outlet..make sure the av cable is connected white-white yellow-yellow red-red...now press play on the dvd
feel free to rate help
Jul 04, 2010 | Toshiba SD-2800 DVD Player
Disc play interrupted
I recomend that you clean the lens to see if that makes a difference.
Also you might want to look at my Tip on dealing with DVD's that jump.
Apr 05, 2010 | Mintek DVD-2580 DVD Player
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
DVDs are playing with green tinge
Greetings and Salutations,
If your using the component outputs from your DVD player I would first check to make sure that the cables for the Red and Blue channels are connected properly. If the cable is connected correctly then try replacing both the Red and Blue channel cable. If this fails to fix the problem try connecting to another component input on your TV if you have one available.
You might also want to check to see if you switched on the progressive scan switch on the back of the VCR/DVD unit. If you know someone with another DVD player have them bring it over and see if the problem is still exists.
If the green picture is still present then the problem is and internal problem with the TV and you will need to find a repair center for it. If the problem goes away then the problem is with the VCR/DVD combo unit. You can at this point also try using just the Video Out from the DVD player.
Hope these suggestions will help you with your problem.
Jan 06, 2009 | Toshiba SD-37VSR Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Screen colour is distorted
hi there
you may want to check the cable that connects your tv and player as this may be faulty already and start to recieve interference. try to clean the lens as well as this also give effect to the screen.
hope this helps.
Feb 12, 2008 | JVC TH-V70 System
Pulsing screen
Are you getting this on all video outputs from the DVD? the yellow analog out + the red/blue/green + the S video? Did you try connecting a different source? a digital cable TV tuner, or another DVD player? sometimes DVD players get screwed on some outputs, while the rest stay fine. I have a DVD that has an analog video out that shows an only black and white picture, while the red/blue/green works fine. Good luck
Apr 21, 2006 | Yamaha DVXS60 System
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
Electro Med Services...
