Question about Panasonic PT-52LCX65 44" HDTV
I cannot reset my lamp clock
I have a PT-52LCX65 panasonic tv and i have just replaced the bulb. I have tried several times to reset the lamp clock but nothing happens, no message on screen.
  • 1 more comment
  • BYEBYE1 Nov 24, 2008
    i have the same tv and i don't know how to get the lamp to reset
  • Anonymous Nov 25, 2008
    tried all tricks on this site. nothing has worked YET
  • Anonymous Mar 14, 2014
    I want to reset the jvc tv clock
Http://answers.yahoo.com/question/index?qid=20080221185527AAvGCui
I just now replaced my lamp and tried the solution on the above bookmarked site (hold down VOL- on the TV itself while holding down the SPLIT button on the TV remote simultaneously for several seconds... I didn't need all 20 seconds that this site recommends), and that worked for me. About 5-10 seconds in, I saw a blue box on my screen that basically said "Lamp timer has been reset to 0" with an "Exit" box below that. It took me a while to find the "Exit" button on my remote control to clear that box off the screen, but that's how I cleared it.
My TV is just short of 3 years old; I bought my Panasonic PT-52LCX65 on "Black Friday" (day after Thanksgiving) in 2005. My lamp died last Saturday night.
Hope this helps! -- ChuckE
Posted on Nov 27, 2008
IS THIS ART
Posted on Aug 16, 2008
How do you reset the bulb life counter after you put in a new bulb?
For models:
PT-44LCX65/PT-52LCX65/PT-61LCX65/PT-52LCX15.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down the SPLIT DVD/VCR CH UP button on the remote until a message appears on the screen that the lamp timer has been reset. If this does not work, use SPLIT DVD/VCR CH DOWN instead.
Good luck
Dec 14, 2010 | Panasonic PT-52LCX65 44" HDTV
How to reset lamp timer on panasonic pt-52lcx16
Turn On tv, press and hold Volume Down button on TV Front and Play/Split button on Remote at same time for six seconds to reset lamp timer.
TV screen will show lamp timer reset display upon successful process.
Jun 26, 2010 | Panasonic PT-52LCX65 44" HDTV
PT-52LCX65 Lamp Meter
Hello.. meseta809
first off all it's not necessary to have the TV on to reset it. the problem is the dmd need to send the info that you have a working lamp.
try this to see if it work's
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Ok, so apparently there are a couple of different ways forum members have found out how to reset their Panasonic Lamp timer (this should apply to all of them, not just the TY-LA1000 specific lamp)
“Hold the VOL down button on the TV and the SPLIT button on the REMOTE for five seconds”
Again, you will need to press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds, it will NOT work if you try to do it both from your remote!
Jan 15, 2010 | Panasonic PT-52LCX65 44" HDTV
I have a Panasonic pt-52lcx65-k. I thought the lamp was gone so i replaced it. Now the tv wont come on at all. Just a orange light flashing. I tried to reset it by holding the volume button and the pip...
Howdy,
Doble check your Lamp Installation, making sure that the Lamp Cover is properly secured. Reset TV by unplugging TV from the wall for 3-4 minutes then plug back in, then turn TV on.
To reset your Panasonic Lamp Time:
ø Press and hold these buttons for (at least) 5 seconds:
ø Volume Down button (on TV Panel).
ø AND ACTION Button (on remote).
As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
Thanks for using FIXYA, BIG IRISH.
Dec 19, 2009 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-52LCX65-K problem to turn on.
THERE IS A SERVICE BULLITIN BY PANASONIC IF YOU GO IN A PANASONIC SERVICE CENTER THE WILL CHANGE THE DEFECTIVE COMPONENTS IN THE BALLAST
Dec 02, 2009 | Panasonic PT-52LCX65 44" HDTV
LP 50 Panasonic Projection TV just replaced the lamp but don't know how to reset lamp clock
Panasonic Lamp timer reset.
To reset the lamp timer
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
asnowman
Oct 07, 2009 | Panasonic PT-52LCX65 44" HDTV
Reseting the lamp meter on tv
1) Press the POWER button to turn your TV on. Make sure you are set to Cable/TV reception. If the "replace lamp. Reset Lamp timer" notice appears, press "EXIT" on your remote.
2) Press and hold the VOLUME DOWN BUTTON on the TV set (not the remote, the actual TV set)
3) Continue to press and hold the VOLUME DOWN button and press and hold the PIP (Picture in Picture) or SPLIT/PLAY button on your REMOTE control (your are pressing and holding BOTH of these buttons at the same time now).
4) After 5 or 10 seconds (be patient), the lamp serice menu will appear and say your lamp counter has been rest to '0' (zero). That's it, you are all done.
Now, I continue to have the power shut off after a few minutes of play. I think it is a problem with the cooling fan. Damn it all anyway.
Dec 21, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic 52lcx65 52in projection tv
I have the same TV had the same problem while under Warranty Panasonic tech replaced the lamp
Apr 15, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-52LCX65 44" HDTV Logo
441 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
