Question about Ovens
Kitchen Aid Oven KERC601
I need to know the color and position of each wire on the original part #9751758 on my Kitchen Aid KERC601 oven.
I do have the replaement switch #8203536 and have there conversion sheet but I may have written down the wrong positions on my orginal switch.
  • 1 more comment
  • JSH12 Jun 06, 2008
    no I don't have the service manual.
  • JSH12 Jun 15, 2008
    KERC601HWH0
    I did not find a diagram for the switch #9751758 only for the replacement
    Genius:
  • 1,665 Answers
You can insert model No at link's search tab to find parts available for your apliance
http://www.repairclinic.com/0047_13.asp
Posted on Jun 16, 2008
  • 3,037 Answers
Usually there are 5 wires to a standard switch. L1 and L2 will be the power going to the switch, which normally are colored red and black. By looking at another switch on the range, you can help determine which color is for what. The H1 and H2 will be the outputs which may also be labeled B1 and B2. These will be the outputs to the elements and are interchangeable. The P switch will be the Pilot and will go to the indicator lamp that will tell when the switch is on.
Let me know if you have further questions with this.
Posted on Jun 15, 2008
  • Benjamin Patri
    Benjamin Patri Jun 16, 2008
    all our premium solutions hve a wrong repost message wat is it?
  • Benjamin Patri
    Benjamin Patri Jun 28, 2008
    If you are satisfied with your experience here, then feel
    free to provide me with some feedback by rating my solution. If you need any
    more help, I would be glad to assist you, just ask.
    Thanks for your time and service and I hope you have a Great Day!
    Master:
  • 638 Answers
Do u need a manual to rectify ur problem.this manuals n all the repairing information will be found on a link that i m providing below also along with proper diagrams
:http://www.repairclinic.com/0047_13.asp
rate the solution as fixya if it helps u solve ur problem.
  • 790 Answers
Hello JSH12!!!
Contact this expert IFIXALL he will definitely help u ...
Regards
Smilemaker
  • Ovens Master
  • 1,879 Answers
What's the remaining 4 characters after KERC601????
  • Ovens Master
  • 13,433 Answers
The wires whould read in a service manual. I would suggest you contact a company that repairs ovens to have them check wires. if you really don't know..
Posted on Jun 06, 2008
  • Ekse Jun 06, 2008
    very hard to locate a service manual for this. you may request support from other expers, maybe someone here knows exactly how to fix this.
    Guru:
  • 1,894 Answers
D u have the serivce manual for this>?
  • dewan nafees ahmed Jun 15, 2008
    i have already tried hard to find a service manual for this.
    its very difficult.
    as ekse said u should buy a service manual form the company or any tech shop.
My convection oven ring does not work
These tend to crack and "unzip" because they are such a tight circle... Kill the power, and meter the ring element for ohm's resistance. If the element tests ok, check the wires to the element for overheating, and if those look fine, remove the control board and look for burnt solder joints where the relays are mounted. Multimeter DM10T
Feb 22, 2015 | KitchenAid Kitchen Aid KEBS177SBL Single...
Tip
Kitchen Aid Oven / Stove Fault Codes
If your Kitchen Aid Oven is showing fault codes starting with F, the problems and solutions can be found at the following website.
CLICK HERE
on Feb 26, 2011 | Ovens
Needd to change kitchen aid wall oven from celsius to fahrenheit
Press and hold the Broil Max Econo button for 5 seconds.
Only this button and without turning on oven.
Feb 17, 2013 | KitchenAid Kitchen Aid KEBS177SBL Single...
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
What distance does the back and sides of the wall oven need to be from the other kitchen cabinets and drywall? What is the voltage and wattage of wall oven? What do the five colors, blue, black, green,...
the installation instructions are in the user manual and the wiring must be done by an accredited , qualified electrician
do anything yourself and the warranty is void
Aug 14, 2017 | Ovens
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Finding replacement part # 4164235 for inner door glass
I am looking for a Kitchen Aid part # 4164235, a Window Pack for the inner door of my Kitchen Aid Oven door.
May 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Amana oven
Error F-9 means:Door lock safety circuit on ERC sensed Replace the door latch assembly
To solve this...Just press and hold the door latch to unlock position and then press cancel for a few seconds. The latch will return to its original position
This will probably fix it..but if doesnt work try this
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Oct 17, 2007 | Ovens
Ovens Logo
144 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
