Hi, I have a Toshiba-Samsung Optical drive in a brand new Dell Vostro 1700 laptop that appears to not work. Click the drive icon and there are a few grinding noises but the PC continues to clock. Dell checked drivers and re-loaded firmware, but no improvement. Do you concur that the hardware is the problem or could it be something they overlooked? GX800 Assembly,DVD /-RW,8X,IDE Toshiba Samsung Storage Technology,CGSY
    Genius:
  • 2,785 Answers
Its seems your rom is having problem better to change it
Posted on Jun 06, 2008
How do i fix a error code message 0f0075d on a dell vostro 1700 ?
There is a possibility that this could be an issue with the hard drive. Request you to use the below link and run hardware diagnostics again:
http://dell.to/190HjBV
Make a note of the error codes that appear along with the validation code (if any).
Jun 29, 2014 | Dell Vostro 1700 Notebook
Dell vostro 1700 start buton not working
they do go bad I had a new DELL that the company would not even look at fixing they said it was outdated before walmart sold it to me but if you know how to access bios then go in there and reset to default . save change and exit .
May 02, 2014 | Dell Vostro 1700 Notebook
I have a dell vostro 1700 laptop didplays for about a minute then goes black I can shut lid then open it comes back on but goes off again after another minute. It does it with the hard drive out too.Can...
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Apr 13, 2013 | Dell Vostro 1700 Notebook
I have a Dell VOSTRO 1700 running VISTA, purchased March 2008 (out of warranty). I used the Toshiba DVD Drive only a few times. Since Oct 2009, the laptop unit (softwarewise) does not ''see'' the Drive....
This is becoming a common problem. Let's see if we can save you $150!!
If your CD-ROM or DVD-ROM Drive Appears To Be Missing then you will need to manually edit your registry.
Follow the instruction below.
Click Start Menu. In the Search box, type regedit, and then click OK. A Registry Editor window will open up.
1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
6. On the Edit menu, click Delete.
7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry
5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
8. Exit Registry Editor.
Step 4: Restart the computer.
This should resolve the problem and there is no easy fix unless you factory restore or reinstall the operating system.
Good luck and please let me know if there is anymore advice that you need.
Jul 20, 2010 | Dell Vostro 1700 Notebook
My cd drive will not read a cd
Here's a good start. Go to the link below and click on the big green button that says RUN NOW. It's a Microsoft Autofix Application that's helped restart many an optical drive for me.
Hope it works for you.
http://support.microsoft.com/gp/cd_dvd_drive_problems
Jul 15, 2010 | Dell Vostro 1700 Notebook
Dell vostro 1700 NETIO.SYS 0xc0000098
This is probably a problem with either the media (bad disk, or picky optical drive) or with some hardware. In the first case, I would try to reinstall first, and if that fails consider using a different drive or disk (if possible). As it points to the Netio.sys file, in the second scenario it may be related to a network device (i.e., ethernet). My suggestion in that case would be to remove all devices possible from the computer, and to disable on-board LAN/audio in BIOS to see if that helps.
Apr 15, 2009 | Dell Vostro 1700 Notebook
Bought used dell vostro 1700, wasnt told about the bios password.
Hi Jonnymac93,
the fastest way to clear a password would be to remove the cmos / bios battery. The manual for the Vostro 1700 can be found at the following link;
http://support.dell.com/support/edocs/systems/vos1700/en/OM/pdf/TT565A01MR.pdf
If you prefer the manual in htm, click this next link & choose htm format listed on the site;
http://support.dell.com/support/edocs/systems/vos1700/en/index.htm
Go to page 182 & 183 for instructions. The manual call this, Removing the Coin-Cell Battery.
Also here is notebooks driver site for the 1700;
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?~ck=ln&c=us&l=en&lnki=0&s=gen
Good luck Johnny!
Run into trouble, post back.
Mike
Mar 30, 2009 | Dell Vostro 1700 Notebook
Dell Vostro 1700 Microphone
got to start,my computer,device manager, hardware and make sure that your microphone is on. Probably on mute.
Jan 08, 2009 | Dell Vostro 1700 Notebook
I can't reinstall Windows Vista for Dell Vostro 1700
my e-mail address is ihab2009@live.se add me to your msn will take u throw et i have same problem
Jan 03, 2009 | Dell Vostro 1700 Notebook
Comp freezes on startup
need more information on your problem could be several broblems
Dec 13, 2008 | Dell Vostro 1700 Notebook
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
