We used nail guns for years. I still own 6 guns, but they aren't used much anymore.
You have a 'blown head gasket.'
Or there is debris from the air hose that got lodged into the gun.
There is a head gasket and a trigger gasket.
Both can blow out any time from use, lack of oil, or they can stick open from debris.
You can take apart the head and clean it up and add oil to see if that solves problem.
You can order a gun re-build kit for your model and put in the parts yourself.
You can have a nail gun repair shop do the job.
Nail guns require gun oil.
If you don't use gun for a while, oil should be put into air hose opening and then left to run down into gun. More oil is better.
If you use 3-in-1 oil or some oil besides gun oil, then it will corrode the gaskets.
When storing air hose and guns, put tape over openings so they stay clean.
Before hooking air hose to a gun, you can also put a blower on hose and blow out the line first
