Question about Panasonic Televison & Video
Hi i have a MR EX77 dvd recorder with built inb turner, great machine though im unsure as to why when i record from the tv on a digital channel the picture when in playback comes out with greenish/ redish and yellow colours through out the picture sound is fine. pls help i bought this cause i was lead to believe u could recorder digital tv
    Problem Solver:
  • 7 Answers
Check for the video codec setting or the video format.
Ensure your are recording and playing using the same format.
Posted on Jun 06, 2008
Flashing red cassete light mean
So.... Who uses a VCR any more. They are ancient history.
They don't last forever so perhaps it's time to think ahead....
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. I got him a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Main Features:
DVB-T Twin Digital Turners
DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
2.5" Sata Hard disk: 500GB
Time Shift Function (Pause live TV)
HDMI Digital Output
Digital Audio Output
CVBS/YPbPr/SPDIF connectors
Supports TV formats 4:3 and 16:9
Electronic Program Guide (EPG) up to 7 days in advance
EPG searching and auto download
Recorded program edit
Parental Control
Copy files from internal HDD to external HDD
Built-in WiFi
Network Playback
USB 2.0 Interface
Cheers
Good Luck
Maybe you can get a little more life out of that VCR still
Aug 15, 2014 | Toshiba W522 4-Head Hi-Fi VCR
How do i record tv programs on digital stations. Only option is analogue.
On the EPG (of the DMRs channels) press OK on the remote at the program you want to record. After that you can choose HDD or DVD-RAM and the quality Ep-Xp and possible subtitles (STTL). Press OK and the recording settings are saved. Note that to record 16:9 or 4:3 aspect ratio, you have to have that setting made from setup.
Nov 09, 2013 | Televison & Video
I purchased a MDR513h/f7 hdd & dvd Player/recorder for my cable TV. I can not watch one channel while recording another. Comast said I must have a dual turner and that is what I purchased (I think)....
This model has only one tuner, I'm afraid. You can only watch one channel at a time, unless you split the cable signal going into it. One side goes to the recorder, the other to the TV. Then you use the single tuner in the recorder to record and the TV's tuner to watch the other channel.
Sep 12, 2010 | Philips Magnavox DVD/VCR Dual Player
I cannot get any tv channels though my panasonic
This model only has an analogue tuner so wont receive anything if the analogue signal in your area has been switched off. either buy a new new with a freeview tuner built in or just use that one in conjunction with a freeview box.
Dec 02, 2009 | Panasonic DMR-ES10 DVD Recorder
How to record digital tv thru reocrder
You need to go into the menu and set the "av-2 out put" to DTV, that should solve the problem, remembering to connect the "in" scart on the recorder to AV-2 on the tv.If there is only 1 scart on the recorder it will be a 2 way connection, sending and recieving a signal.
May 29, 2009 | LG RH177 DVD Recorder/HDD Recorder
Can't recorder digital broadcast
Hi,if your vcr is an analog machine then you will not get a signal.If you have a seperate digital box then you can connect this via a scart lead to av2 on the vcr.Best thing though is to buy a digital dvd recorder.hope this is of some help.jamie
Mar 02, 2009 | Zenith XBV443 DVD Player/VCR
Panasonic DVD Recorder DMR-EX77 My DVD Recorder is communicating between the Remote Control and the DVD Recorder, but the Recorder is not communicating correctly with the television. The DVD Recorder seems...
It sounds as if the actual T/V channel is out of tune.
I,d suggest powering the player On.
Then using channel 8-12 on the T/V to Scan for its frequency.
When you,ve located it to the Player.
Lock the channel, then use the DVD on Channel 8-12.
Mike @ compurepair.
p.s also check the output from DVD To T/V lead has,nt come loose.
Mar 17, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Is there a solution?
I have a similar setup. Your problem is because you are selecting the recording on the digital tuner of the TV. When you do this you need to keep the TV on and canot switch channel.
You should make sure you use the digital tuner on the DMR-EX77 recorder and then you can use the TV as you like.
Oct 09, 2007 | Panasonic DMR-E80H DVD Recorder
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
Televison & Video Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
