Question about GE JBP70SKSS Stainless Steel Electric Kitchen Range
Oven Door is locked and will not open
Self-Cleaning oven door will not open - This is the second time this problem has occurred. First time a Handyman pulled the entire stove away from the wall and seemed to "push or reset" something that was responsible for the self-cleaning feature. The door then opened but the Handyman said a part needed to be replaced and that it was fairly expensive. He said that if we weren't concerned about self-cleaning, the oven door would now open and close O.K as long as we didn't shift the manual oven door lever all the way right, putting it in the "Clean" position. We've used the oven since then (about three years) without a problem, not concerned about the self-cleaning feature not working. About a month ago we had a problem with the oven door not closing all the way. Trying to fix it, the door finally closed all the way but now it will not open. I'm guessing that the manual lever was inadvertently shifted to the "Clean" position.
Any advice would be appreciated, particularly if i can avoid the cost of a repairman. Thanks in advance.
George Gill have a frigidaire self-cleaning stove set the self-cleaning cycle and left it the stove is cold now but the door will not open I have looked in the manuel but can not find anything on how to open the oven door
  • 3 more comments
  • Anonymous Jun 25, 2008
    i haven't taken any steps to fix it
  • douga156 Jul 13, 2008
    This is the first time that I have used this option and the door is locked and won't open. Any suggestions?
  • jprater2006 Jul 22, 2008
    I cannot get the door opened on my GE Electric Oven after attempting to use the self cleaning feature. I stopped the self cleaning feature shortly after starting it as I didn't have 4 hrs and 20 minutes to wait. Things I've tried:
    Unplugged the oven to see if this would disengage any auto command to keep the door locked.
  • dotboy Nov 24, 2008
    door lock will not open after cleaning
  • mauree Nov 24, 2008
    I have the same problem.I used the self cleaning feature I can't get the oven to open and it's almost thanksgiving
  • 413 Answers
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Posted on Jun 06, 2008
    New Friend:
On my White Westinghouse I can unlock the door by starting the self-clean cycle for one hour, wait 15 seconds, set stop time to 0 hours, push the stop button, and voila, door unlocks.
Posted on Apr 09, 2013
My Gibson Oven oven door will not shut because lock mechanism wont retract?
You almost certainly have a bad lock motor & latch assembly. Please provide model & serial # if you'd like more help, and with more detail on exactly what it will take to repair the oven.
Jul 27, 2016 | Ovens
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Wait 20 seconds.
  • Wait 20 seconds.
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
When cleaning the stove i touched my accident the
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
Self-cleaning error message f90
unplug the range.
wait 1 minute.
wait 2 minutes.
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Self Cleaning
unplug the range.
wait 1 minute.
wait 2 minutes.
Mar 03, 2008 | Kenmore 94220 / 94221 / 94222 / 94224 /...
GE JBP70SKSS Stainless Steel Electric Kitchen Range Logo
964 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
