Question about GE Washing Machines
The water not cutting off on the cold side it keeps running thur all setting . The hot side cutting off ok
  • 5,911 Answers
The problem is associated with a defective cold water solenoid in the water inlet valve. If you replace the water inlet valve this will probably take care of your problem. Please post back with your complete model number and I can give you advice on how to access it and where to obtain parts.
Posted on Jun 06, 2008
Hot water keeps running hot and old
Fastjet,
I can't understand what you are asking...
Please clarify via a comment.
perhaps a leak?
Jan 09, 2015 | Water Water Heaters
My Hamilton Beach water cooler is just dripping water on the cold side but running free on the Hot side.Yesterday I flushed the cooler out with vinigar and hot water but today we have a problem
I have same problem keeps running till freeze up so i put a timer on the power cord it shuts off at 11.00 pm till 6am in morning the water keeps pretty cold and a lot cheaper then a new board or scrapping the cooler after starting for about an hour water is cold
Jun 18, 2012 | Hamilton Beach Water Cooler with Storage...
Water keeps running in i have got to cut water off to spin dry
There is an electrically controlled water valve for both hot and cold water on the back of the washer, do both settings not shut off? if it is just the cold pull the washer out and replace the cold water solenoid water valve.
Mar 10, 2011 | GE WSXH208A Front Load Washer
GE WPSR3100W0AA Does not run on Hot-Cold temperature mode, only on cold- cold or warm-cold. Hot water hose and faucet are ok and ON.
you can switch the hoses to verify that the temp selector is working if you have the cold water supplied to the hot side and run the machine on hot-cold side and nothing comes out then replace the water inlet valves.
Nov 21, 2010 | GE Profile WPSR3100W
Water starts of hot but then starts to get cold.
You need to verify that you still have hot water. Sounds like you're running out.
Sep 28, 2010 | Home
Washer runs but the water does not turn off, THe waterm hot and cold just run until I cut it off manually.
while machine is filling turn of power if the water is still entering machine you have a mechanical fault water valve hot or cold needs replacing if water stops when power turned of you ave an electrical or control problem check water level hose from tub to level switch for damage or perishing if ok check water level switch blow into it see if it clicks if not replace also while blowing hold pressure to see if the diaphragm in the pressure switch is not perished keep me informed
Nov 05, 2009 | Washing Machines
Hot water taps and showers pressure very low cold taps ok
there is a little cap on the hot and cold side above the shut off valves, turn the water off at these valve and take the caps off there are filters in there clean them off and reinstall them that should take care of the problem, you might want to flush the tank while your at it hook a hose to the hot side connector and run it out side or to a sump pump then turn on the cold water and flush it out you can also reverse this procedure by doing it on the cold side
May 24, 2009 | Rheem Tankless water heater for 1-2...
Hot water is cutting out after 2 - 3 minutes whilst showering
check the screen on the cold water intake on the cold side,, you might have to flush the system out, and do you have the shower head water restricter in, if not you may be using to much hot water,,, how many other hot water fixtures are running at the same time? try running just the shower,,,if this is a tank water heater the dip tube could be bad that is on the cold side it takes the cold water to the bottom of the tank and forces the hot water out,, if you ar only getting a couple of min of hot water and the dip tube is bad it is not going to the bottom but just at the top and not getting all the hot water you will need a plumber
Mar 21, 2009 | Water Heaters
Cold water no flow on Kenmore front load washer
Check cold hose to see if it is clogged or the filter in the end of it is. Make sure water freely coming out from the tap. If that is all ok then replace the watter control valve on the cold side.
Dec 31, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
