Question about HP Compaq Presario SR1300NX (PP195AA) PC Desktop
Compaq presario SR1350NX problem
My comp. doesn't start to load windows. restart and restart again.
i have fixboot, fixmbr, chkdsk /p /r but doesn't stop the problem.
could you please help me?
  • yohanesbk Jun 09, 2008
    Hi Irish,
    Thank you but how to install the antivirus because I can't go to windows or safe mode/ safe mode with c: prompt. also, I can't take-out my hardisk to install to another computer
  • yohanesbk Jun 11, 2008
    I can't tried this solution because I can't go inside to safe mode or install the antivirus. Also, I can't take-out my hardisk to attach to another computer.
    President:
  • 2,712 Answers
Looks like you have a boot sector virus. Go here and download an antivirus for boot sector:
Avira AntiVir Bootsektor-Repairtool
If that does not resolve the issue, Try going into Safe Mode and see if you can get into Windows. If you can, then it could be that one of the drivers is conflicting with another and you may have to rei.nstall the drivers
Posted on Jun 06, 2008
  • Swilin Sampson
    Swilin Sampson Jun 11, 2008
    Once you download the Avira AntiVir Bootsektor-Repairtool
    (on a working PC, of course) andrun it, it will straight away prompt you you burn it on a CD. Once you burn it, place it in the infected PC and change 1st boot device to CD ROM in the BIOS.
    Besides, there is no way to get into Windows, if you have a boot sector virus :) Also transferring your HDD is not a solution, as the Virus is on the HDD, and no matter where you replace it, you will still have the same issue..
    I do hope you will reconsider your rating and at least give a Helpful rating, if not a Fixya, as Thanks for trying is a negative rating..
  • Swilin Sampson
    Swilin Sampson Jun 14, 2008
    Is your issue resolved? If it is, please change the rating to Fixya to close the thread. Thanks.
When I turn on my Dell DM061 (Windows Vista) Desktop the Microsoft Windows loading screen doesn't load properly and immediately goes to Startup Repair- which says it can't fix the problem. Before this...
all these symptoms can be from ram stick fault, graphic card or graphic section of the mother board or a failing hard drive
you will probably have to have it properly diagnosed by a computer repair shop to find out exactly the failing component
Mar 25, 2017 | Dell Dimension Computers & Internet
Compressed boot in win 7
boot the CD-Drive first. For more information please visit HERE.
Steps:
1.Insert the Windows 7 OS disc into your CD-drive and restart the computer.
2.Wait for the setup window to appear
3.Press Shift+F10 simultaneously to bring up Command Prompt
4.Type in Code: bootrec/fixboot then press enter
5.Last but not least type in Code: bootrec/fixmbr then press enter
Nov 19, 2011 | Compaq Presario 700 470024-192 Notebook
E- computer turn on then the screen says it was shut off improperly. say click to restart or wait.....did this it ran through its process and went to screen with no signal. ran it again under boot and...
looks like it's stuck in a startup loop, can you boot from a windows cd into repair console (press R to repair with xp, choose repair my computer with vista or 7) ?
if so, type the command fixboot and after that fixmbr, if it still doen't work, try the chkdsk /F /R
command. if that doesn't work, try booting in hirens boot cd (download v13 and burn it to a cd rom) if still no success, you need to reinstall windows, if that doesn't work, replace the harddisk and reinstall.
Jun 17, 2011 | E-Machines eMachines Desktop PC
sounds like your windows installation took a hit, try booting from the windows cd into the repair console and do a chkdsk /F /R; a fixboot and an fixmbr command. if ths doesn't work, try the repair option. You can also try to boot from a hirens boot disk and try the tools that come with that.
I can't open my Compaq Presario c700 and I got this msg: bootmngr is compressed.
Boot from your Windows CS and select Repair your Computer -> Command Prompt, execute the following commands:
bootrec /fixboot
bootrec /fixmbr
Reboot.
Dec 27, 2009 | Compaq Presario 700 470024-192 Notebook
Bootsafe error on hp compaq notebook notebook pc while booting
Boot from the XP disc and press R at the first screen. This takes you into Recovery Console. Run these commands:
fixboot c:
fixmbr
exit
The computer will restart and hopefully it will load Windows.
If not, is your computer making clicking sounds?
Jan 25, 2009 | HP Compaq Presario SR1920NX PC Desktop
Error loading operating system
If you take a hard drive for one computer to another the windows wil have to be reinstalled as windows looks at the hardware configuation and if it doesn not match, will not run. If the 20 gb hard is working , reinstall it then using backup software back it up to another hard drive.That will work. Personally I use" Acronis true home" software to change a hard drive but their  are other  wil also work. Some  backup and transfer softwware even come with the replacment hard drives.
Dec 10, 2008 | Compaq Presario 5000 PC Desktop
REINSTALL XP HOME EDITION ON Compaq Presario SR1350NX Desktop PC
Files copy errors during the XP installation process are often an indication of BAD RAM.
If you have dual RAM modules, try install with 1 memory module installed
May 19, 2008 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
Compaq Presario 1681
Put your windows installation cd in the drive, then reboot. Press any key to boot from cd. Then select R to enter recovery console. Follow the prompts. Once in the recovery console, you should have a C:\ prompt. When there type "fixmbr" without the quotes. Once that finishes type "fixboot" and then let that finish, you'll probably have to type a "y" for yes stating that you want to do these options. Then finally type "chkdsk". This should solve your problem, if not let me know, you'll probably need to do a repair install.
Aug 28, 2007 | Compaq Presario 1681 PC Notebook
HP Compaq Presario SR1300NX (PP195AA) PC Desktop Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
