Laptop screen flickers then goes very dark - Computers & Internet
  • rexterdexter Apr 07, 2009
    Hi, I have a Samsung R700 laptop (17" screen) which has a faint flicker, almost like the LCD panel connection is about to fail. Similar to a fluro light tube flickering before it finally blows. Once the screen did go black but I could still see that the screen was working perfectly (except for the LCD panel that had turned off). I rebooted the laptop and it worked OK, but the faint flicker is still there. If it's the LCD panel, how would I go about seeing if the connection is loose? It's still under warranty but I'm concerned that they dont fix it as it's an intermittent problem and easy for them to say it's fine and there's no problem.
    Many thanks in advance.
    Novelist:
    Champion:
  • 256 Answers
The flickering of the screen is caused due to the problems with the inverter.
Inverter is the part which provides the power to the backlight.
Sometimes you may see a white color on the screen.
In this case the connection between the motherboard and the monitor may be damaged.
To solve this problem, replace the inverter with a new one and also repair the damaged connections.
Get more information to fix laptop screen flickering problem :
http://supportforsamsung.iyogi.com/nb30/screen.html
Hope this information helps you.
Posted on Sep 13, 2011
    Sergeant:
  • 458 Answers
Did you check the sleep mode or power off mode? What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future. If you need more help, feel free to keep asking, but keep the original information so I can see it.
Posted on Jun 06, 2008
  • 1 more comment
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you solve your problem? Let me know if you are still having problems so I can help you more.
    Are you still having this problem? Did my answer solve your problem?
    Rate this as a Fixya if it is fixed.
Dark screen and flickering on the laptop computer model pcg 61611L
I would check the GPU by connecting an external monitor before booting it, that will allow the external drive to automatically work.
Jan 02, 2014 | Sony VAIO Computers & Internet
It's a little over a year old. The screen will randomly start flickering and gets really dark and I can't see very well and sometimes just goes black altogether. It is very frustrating and sometimes when i...
Sounds like a loose connection at the inverter board. Laptops use an inverter to step up voltage to drive fluorescent tube(s). The problem could be at the inverter or at the tubes.
Mar 12, 2010 | HP Pavilion dv5-1125nr Notebook
THE SCREEN FLICKERS ALL THE TIME, HOW CAN I FIX IT
The screen flickering could be the screen inverter starting to fail. The inverter sits under the screen behind the bezel, it takes the low voltage DC power from the power adapter and converts it to high voltage for the screens backlight. If the inverter starts to fail, you either get a dim display that finally goes dark or get flickering like you see in some store lighting fixtures when the flourescent bulbs are failing.
Jan 15, 2010 | Acer Aspire One AOA150-1570 Notebook PC
Blue screen flickers and goes almost completely dark... when i plug into a different monitor, everything on that monitor is clear, so i know the compputer itself is fine. How do I check for a loose
most likely inverter issue, or somewhere in between inverter and LCD, illumination bets thing to do is to take aprt the LCD frame and disconnect and reconnect all wires leading from the inverter. If that doesn't work, the replace the LCD wires and or inverter.
May 20, 2009 | Acer Aspire 5100 Notebook
Laptop screen
Sounds like the switch that tells the cpu when it's open or closed is going bad. On most laptops there is a little switch that protrudes from your keyboard (usually in upper corners). Try cleaning it with isopropyl alchol(rubbing alchol) and a q-tip and see what happens. If you can't locate the switch on your model get back to me and i'll research a little deeper for you. Hope this helps
Sep 14, 2007 | IBM ThinkPad 770 Notebook
Computers & Internet Logo
1,588 people viewed this question
David Payne
David Payne
