Question about Gateway FPD2275W LCD Monitor
I want to remove stand 'holder' so I can mount on an Atdec V-AT-DB Dual Focus LCD Desk Mount
I bought two Acer 19" p191w monitors (sometimes referred to as p191wd). I want to take off the stand AND THE STAND "HOLDER" (that's attached to the back of each monitor) so I may mount each on an Atdec V-AT-DB dual focus LCD desk mount (it holds two monitors so you can move them around, pivot the monitors, etc. It looks pretty cool!)
How can I take off the stand 'holder' (the female part that receives the male part of the stand itself). The female part is affixed to the monitor and I can't figure out how to remove it.
Any help?! Surely this has to be possible! I read it is "wall mountable", and it has four screw holes for doing this.
See https://www.pacificgeek.com/product.asp?id=86499&c=232&s=947 for info on this monitor.
Thanks!
  • Anonymous Jun 16, 2008
    i have the same problem.  did you figure it out?
  • Anonymous Jul 25, 2008
    yes i have LG 192W and i want to install wall mount ..same problem, cannot remove the stand
This is an old post but for others with the same problem;
There are two plastic snap on covers, one on each side of the stand hinge. Slide each small cover in towards hinge. Pry up each plastic cover. Remove hinge screws, hinge, replace screws, replace plastic covers.
Posted on Feb 20, 2009
I have the same problem and I hate to admit it but I'm on the verge of putting a blade in my hand held router and cutting the plastic away. I don't want to do that since maybe I may need the mount someday, but...
Posted on Aug 01, 2008
Can the monitor height be adjusted. It seems to be fixed to the stand with no adjustments?
No but you could always put something under the stand most can only be tilted for lighting reasons.
Jul 04, 2011 | Princeton Digital VL1916 19" LCD Monitor
Hi we have samsung lcd 22 inchess.. we need to fix it to wall and there is no backside stand .. how can we get the stand
Most electronic stores sell wall mounting brackets. There are several types. one mounts the LCD screen flat to the wall with a limited range of tilt. Another type mount the LCD screen on an arm that allows tilt and swing movements.
Jul 22, 2010 | Samsung YP-K3 MP3 Player
Monitor stand screws
More likely to be metric M4 screws, 1/2" will more likely to be long enough.
Feb 23, 2010 | Acer AL2423W LCD Monitor
Monitor stand
I have one or two nice used Original ones available.
Where are you located ?
email bammbamm@ptd.net if you want pictures and costs
Mar 05, 2009 | Acer AL2017 20" LCD Monitor
Hoe do I remove teh attached stand on an ACER AL 1913?
Where the footpiece joins up with the screen, you'll find a round cover from left to right which just clips in. carefully squeeze the ends and pull away untill released. under the cover you'll find four screws that holds the footpiece and screen together. Good Luck, jus004
Jan 05, 2008 | Acer AL1913 19" LCD Monitor
How do I remove the stand?
Looking at the manual
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=761&formid=3425&website=AcerPanAm.com/au&siteid=8116&words=all&keywords=&areaid=12
It doesn't appear to accept a standard VESA mount to enable mounting on anything other than the supplied stand.
Dell 1900fp 19" moniter Ultrasharp
Button on the bottom back base raises and lowers, if not low enough then you can remove the base. removal button is back and center of monitor.
of course you will have to deal with a way to mount it then.
Dec 12, 2007 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
Gateway FPD2275W LCD Monitor Logo
785 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
