Question about NetGear WGR614 Router
Net gear wireless router
How do i like set up the router because i dont have the cd?
    Novelist:
  • 144 Answers
Hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your
computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power
cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to
appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear
stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
Posted on Jun 11, 2008
I cannot connect to my home wifi I cannot promise you that my product is correct but I do have a case number with net gear #15021142
Your product model no is WNR1000v3...connect your compter to the router with ethernet cable to any of the LAN ports. Go to www.routerlogin.net . Default username is admin and password is password. On the left pane select wireless setting under basic settings. You can see you wireless settings info. Note all the info and try to connect to the wireless network with that info.
Apr 26, 2011 | NetGear WGT624 Wireless Router
Lost my cd for net gear wireless-N Dual Band WNDA3100v2 how can i get another one
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Aug 26, 2010 | NetGear RangeMax Dual-Band Wireless-N...
I did not get the installation CD with my netgear router WGR614 v7. How can I install the router and set up my security pass?
mcdevito75 here, you should contact Net Gear online or by phone thru the manual instruction book with the router package.
Jun 25, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
Net gear box won't connect wirelessly with my lap
Then you need to connect the computer to the router ad the modem to the router.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
Dont know net work key
ok, goto 192.168.1.1.
acoording to the manual of a simlar router,
you need to set the SSID to name the network
then create a Pre-Shared Key, now insert the cd on the machine you wish to connect to this network , if you have no CD give me the model number of the Wireless stick then hopefully we can get a driver, if you insert the hardware it may not pick a driver or it may pick a driver that will not work correctly so disconnect the wireless stick, install the driver then when prompted insert the stick , the driver will be on the CD otherwise give me the model number or goto google and search on that model
Jul 25, 2009 | ViewSonic WR100 Router
Net gear was completely disconnected from computer. net gear WPN82r v 2 was inadvertently reset. dont have a password. any help
To bypass the wizards, connect the router via an Ethernet cable, log in from a DHCP enabled (IP & DNS) computer at
http://www.routerlogin.net/basicsetting.htm
User name is admin and the password is password, both in lower case letters.
Note that wireless connectivity is off by default. When you configure this router manually , remember to turn the wireless connectivity on.
Jul 11, 2009 | NetGear RangeMax WPN824 Wireless Router
Wndr 3300 net gear router wont work with hn 9000 hughes net modem
I went to the Hughes web site to check out the modem. They say it is also a router. I think you will have to disable the router abilities of your WNDR 3300 Net Gear Router.
Get into the Netgear setup by loging on to it.In its WAN setup select Static IP Address and set the Static IP Address to the same as the hughes modem, except for the last number which should be about 50 greater. IE: Hughes 192.168.12.1 and Netgear 192.168.12.55.
In the DHCP setup, disable the DHCP Server
In the Wireless setup, Give your network a name is SSID. You should also set up security to keep others off you internet connection with a WEP key.
I hope this helps.
May 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Dont know how to install wireless net gear for wireless ant.
The instructions are on the CD that should have come with your adapter. Few companies supply anything in print now; the manual is usually in a pdf file.
Put the CD in and start the installation program. It will probably start automatically, in fact. The program will guide you through whatever steps you need to follow. Usually it's just a matter of installing the required drivers, maybe restarting your system, then plugging in the adapter.
Once the adapter is installed, you run the connection software, pick your network from the list it will show you, enter any security passphrase your network requires, and you're wirelessly connected. You may also need to configure wireless operation on your router if that hasn't been done yet.
Apr 20, 2009 | Computers & Internet
The other day i plugged a net gear adapter in thinking it would connect me to the network at work, but i realized it was just a wireless adapter, and my computer is already equipped with wireless. Anyway,...
First, I would go to the control panel (start, control panel; or start, settings, control panel). Then got to Add/Remove Programs. Scroll down the list until you find what looks like netgear software and try uninstalling there.
If that does not work or you can't find it in the list, you could try inserting the install cd again. Check to see if there is an unistall option, and perform an uninstall. Or, if not, then try installing it completely, then uninstalling it via CD.
Mar 18, 2009 | Computers & Internet
NetGear WGR614 Router Logo
61 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
