Question about HP LaserJet 4100n Printer
4100 Dirty Paper Output, Help Me
I have black smudges and marks appearing on my print outs some times they go away and then a few pages later they will reappear. It does this on the auto and manual feeder.RegardsPaul
    Sergeant:
  • 458 Answers
Did you run the head cleaning process in the settings?
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future. If you need more help, feel free to keep asking, but keep the original information so I can see it.
Posted on Jun 06, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you solve your problem? Let me know if you are still having problems so I can help you more.
    Are you still having this problem? Did my answer solve your problem?
    Rate this as a Fixya if it is fixed.
How do I fix my Samsung Multi-function laser printer which has started to print smudged pages.
try to stop the sheet just before it enters the fuser and see if the marks are on the paper already. if not then it has to be the fuser if they are them you have another issue.
Jan 15, 2015 | Samsung CLX-3175FN Color Laser All-in-One...
My HP 4100 printer prints with a black smudge clear down the page. I clean the roller but continues to print bad copies. Should I replace the cartridge?
Problem is either the cartridge or the fuser.
Put paper in the manual feed tray(tray 1)
Print something. When the paper gets 1/2 way into the printer, open the
top cover. Pull out the toner, look down at the paper.
If it has the smudge replace the toner. If no smudge, replace the fuser.
Apr 29, 2011 | HP LaserJet 4100n Printer
Black smudges down left side of page
How do I clean white or black spots on printed documents? Description: First make 10 to 15 copies of a blank, white sheet of paper.
If you still see the spots on printed documents after making multiple copies, clean the drum unit as follows:
  1. Remove the drum unit and toner cartridge assembly, and then remove the toner cartridge from the drum unit.
  2. Position the print sample in front of the drum unit so you will know the exact position on the drum that is causing the poor print.
  4. Turn the black gear on the drum as you check the surface of the OPC drum.
    The OPC drum is photosensitive so do not touch it with your fingers.
  6. When you find the substance on the drum surface that matches the print sample, gently dab the surface of the OPC drum with a cotton swab that is lightly dampened with isopropyl alcohol.
  7. Note
      • Do not use a scrubbing or wiping motion because this might damage the drum.
      • Do not try to clean the surface of the OPC drum with a sharp object, such as a ball-point pen, because this might cause permanent damage to the drum unit.
  8. If the print quality still has not improved you need to install a new drum.
Dec 02, 2010 | Samsung ML 2010 Laser Printer
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Black marks and words on paper
Toner Black marks can only come from two places.
The toner cartridge or the fuser.
The best course of action would be to remove the fuser with the power off and line up a sheet with the problem with the fuser to see if possible to line up the mark and see if the fuser has a like defect in that position. I use inches but it is possible 79-80mm would be the edge of an envelope if you print them and I have seen instances where some envelopes over time cause a line on the fuser which then shows up on regular paper.
Hope this helps.
One more Method to sort out.
1. If a duplexer is installed, remove it. If a duplexer is not installed, remove the tray 2 dust cover from the rear of the printer by pulling from the bottom.
2 Remove the rear cover/rear output bin.
3. Rotate the two blue levers on the fuser assembly up to the unlocked position.
4 Pull the fuser assembly straight out of the printer.end chek de fuser.
5. When reinstalling the fuser assembly, be sure the blue levers are initially in the unlocked position.
6 Make sure the fuser assembly is seated fully before rotating the blue levers down into the locked
position.
Hope both informations will solve your problem.
Please have a regular maintenance agreement with local vendors for your printer to get serviced every month.
Best of Luck.
Jul 21, 2009 | HP LaserJet 4100 Printer
Brother MFC 7820N Smudging Concern
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Printing Black Smudges
You could print a few more out and see if it goes away.
Check the drum and see if there are any black marks on it. If there is, it could be a scratched drum or the cleaning blade isn't working in it anymore.
Is this a new toner cartridge?
Be careful when you look at the drum at it to keep the light out of it as much as possible.
Where did it jam at?
Jun 13, 2008 | Samsung CLX-3160 All-In-One Laser Printer
Toner being deposited on back of page
point check
1.Hallo your rollers are dirty and smudged
2.Is your fuser unit O.k (clean)
3.is your paper good quality or are you using coated paper the wrong side? thereby staining the fuser unit (the hot part of the printer)
4. Most unlikely but have u ever turned your printer upside down??? or excess sideways tilt thereby releasing waste toner from the bottom of the printer to the roof then to your paper???
if all is nay then remove all toners and give your machine a gool blowout
labatt
Apr 26, 2008 | Epson Aculaser C1100 Printer
Black mark on right side of paper
You either have some white out or some other dirt on the scanner or some sections of the scanner are bad. Open the area where your originals feed into, and look for about a 1/2 inch wide strip of glass, that is the scanner window. When that gets dirty, or fails, that causes the problem. Most likley dirty, some whiteout or ink on the scan window.
Mar 18, 2008 | Brother IntelliFAX 4100 Laser Fax
Minola print smudge
Pleas check the imagine unit drum, is it clean or does there are the same marks as in paper.
if yes, the IU drum cleaning or drum itself is damaged and needs to be replaced.
Try:
after sending a print job, when printer has take a paper from tray, open cover, open cover before the paper enter the fusing unit, then you can see, if the mark is allready in the paper then the problem is in the IU or toner cartridge, if not, then fusing unit rollers.
Dec 31, 2007 | Konica Minolta magicolor 2400 Laser...
HP LaserJet 4100n Printer Logo
249 people viewed this question
Ben Johnson
