Question about AOC Computers & Internet
Drivers Sir we are using windows 98 Operating systems We Puchase AOC 177Sa TFT Monitor This monitor resolution does not supporting on that os, So Please send a Solution for that
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Windows 98 is pretty limited and ten years old. Your monitor is pretty new technologically speaking.
    Still, your OS will support the basic resolution for your Monitor. However, your video card may not a probably does not.
    You will end up in a nearly endless exercise in upgrading one component after another to user your monitor.
    Do you think you may be better off spending your money on a second hand PC that is only 2-3 years old?
    Regards,
    Worldvet
    Sergeant:
  • 458 Answers
Go to your monitor resolution and change it lower. Then change the refresh rate if you need to/
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future. If you need more help, feel free to keep asking, but keep the original information so I can see it.
Posted on Jun 06, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you solve your problem? Let me know if you are still having problems so I can help you more.
    Are you still having this problem? Did my answer solve your problem?
    Rate this as a Fixya if it is fixed.
Plz help me to set my aoc 19 inch lcd for operating system windows 7
Settings are dependent on video card not OS. Try changing resolution to different scale.
Aug 27, 2012 | AOC 917Sw 19" LCD Monitor
Monitor not recognised
Many brands and models of computer devices are not automatically recognized, because they're not included in the OS database (which sometimes is updated). Without knowing the OS you're using, it's helpful to use the most current drivers, matched to your OS.
Just in case you didn't have the available drivers, here's a link to them on the AOC website:http://us.aoc.com/support/downloads/driver/63
I hope this helps!
Feb 13, 2012 | AOC 2036sa 20"TFT LCD Monitor
We have purchased two e950Sw LED 18.5 monitors to replace the crt monitors on two of our computers. Old monitors worked fine. Both of these monitors when hooked up get the "No signal" message....
Your old monitors might have had a higher screen resolution or and incomparable resolution for your new monitors.
Probably the easiest way to get them to work is to plug the old monitors in then go to your control panel / display and set the resolution to 1366 x 768 as this is the native resolution of the e950Sw LED.
Chris
Jul 08, 2011 | Computers & Internet
I have a AOC 177sa-1 Monitor with a bad light bulb where can I buy a replacement so I can get it fix
WWW.LCDPARTS.NET
Are you sure that the lamps are bad, very delicate repair works.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed AOC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 16, 2011 | AOC 177SA-1 (BLACK) Monitor
I hooked my new aoc 20' monitor up to our emachine and cant find my cd i got with the monitor to download. the monitor will go out on me few times during the day for no reason so am thinkin i need to...
You do not need the driver for the monitor if you are running XP, if you are running Windows 7 you will need the driver so you can adjust the resolution to the native resolution of the monitor.
Lack of driver for the monitor will not cause the black out problem.
You should try this monitor with another PC first to make sure it is not video card problem in the PC.
Is this monitor still under warranty.
AOC driver download from AOC:
http://us.aoc.com/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Dec 31, 2010 | AOC 2036sa 20"TFT LCD Monitor
Dear sir , i have an intex branded desktop with 17' TFT monitor . i m using windows XP in this system . sir today i increase the resolution of visual from XP and just after that my monitor gives an error...
Obviously the graphics card is not capable of supporting the resolution you have set so it go's blank.
Although you can set the resolution via the computer the system will not change it back when you save that setting even though you see nothing, the computer doesn’t know you can’t see anything.
You need to go into the monitors menu (a button on the monitor front panel) and set it back to a supported resolution or default.
Start at 600x800.
Once you see an image on the monitor right click the desktop go to properties then settings and slid the screen resolution bar to the right to a resolution that suits you don’t go to high or you will get the same problem.
1024x768 would probably suit you.
Hope this helps.
Sep 12, 2010 | Computers & Internet
Input Not Support
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears. If you use Windows Vista oder Windows 7 you can access the resolution windows by right-cliking on your desktop and selecting "Screen resolution".
Jul 18, 2010 | AOC 19LVWK LCD Monitor
When I Increase the Resulotion 1027 X 768 then display a message box " Inpur not support" and move arround slowly on the screen . my Motherboad is Mercury i installed the vga but problem is same...
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears.If you use Windows Vista or Windows 7 you can access the resolution window by right-clicking on your desktop and selecting "Screen Resolution".
Jul 02, 2010 | AOC 19LVWK LCD Monitor
Resolution problem with AOC TFT 185W80PF
Monitors don't need drivers to function. Either you need to configure it or it's dead.
Mar 16, 2010 | AOC 19" LCD HDTV Monitor
Computers & Internet Logo
176 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
