SOURCE: Wiring
Hi kevin, With the ground already hooked up, it does not matter which terminal you hook the X or Y too on the heater. The heater is AC and a resistive load. This means it doesnot have polarity, and will work both ways. You done good getting high temp connectors, do you have high temp wire?
SOURCE: star popcorn maker need insulation part between element/and pot?
there is insulation between the element and the outer kettle. This insulation can get brittle and crumble with age. I was lookiing for some parts as I have this kettle also and was told the kettle and parts are no longer available. If anyone has access to these parts please email me at [email protected]. Thank you. Gary
We
have a dryer ( could be any make! ) that is
consistently blowing fuses after about 15-20 minutes. We have taken
the dryer apart to check for clogs in the venting system and to check
if the heating core was okay and they seem to be fine. Any ideas?
Blowing
the house fuses? If yes....the dryer usually will blow a fuse right
away if there is a problem in the dryer....more often than not a fuse
that blows after the dryer has been running a while it is a fuse box
issue. A test: Put 2 new 30 amp fuses in and run the dryer with the
heat on for 5-10 minutes, turn off the dryer and
quickly remove the fuses from the house fuse box and see if they are
hot at all ( especially on the bottom )....if the fuses are getting hot
they are
probably melting the fuse link and not really blowing = fuse box
problem.
As for most things there are exceptions....a grounded heating element
-may- blow the fuse after the dryer has been on for a while, it is easy
to test for that as well. See. A burnt/loose power cord/plug -may- also give this type of a
problem.
Dryer basics- Venting problems and
power supply:
Most dryer "to long to dry" or "poor/low
heat" complaints can be traced back to a bad or poor
venting system and sometimes a poorly maintained lint filter. Do not go outside and put
your hand under the vent opening and say " it is fine - I feel air coming
out"...that is not good enough...take your venting apart, clean it ALL
out and make sure the vent hood flapper works and that it is not clogged with lint. Make
sure your venting system is short, straight and resistance free as possible. A poor
venting system will shorten the life of your dryer, plug up the fan blower and duct work
inside your dryer as well.
Gas dryers need 120 volts to operate the whole dryer.
Electric dryers need 240 volts to operate the heating element and 120 volts to operate the
timer and motor. You should see 240 volts between the black and red wires, 120 volts
between the red and white wires, 120 volts between the black and white wires at the
electric dryer main power harness. A blown house fuse ( or breaker ) would stop a gas
dryer from working at all. A blown house fuse ( or a 1/2 tripped breaker ) would still
allow the electric dryer to run but you would get no heat. Depending on which fuse goes,
sometimes the dryer could be dead as well. If you have problems with a fuse letting go or
a breaker tripping after the dryer runs for a while, normally the problem is not in the dryer but is in the fuse box.i think it will work
