Samsung 2232 monitor will not go on. Power light is blinking blue
  • 2 more comments
  • joshuajventu Oct 14, 2008
    tried different cable. got anntoher monitor to work on the compy, but the sasung just wont show a picture. same blue blinking light though.
  • curlyhoward Apr 13, 2009
    My Samsung 2232BW will not display a picture either. The blue power LED is blinking rapidly, about twice/second. Went through troubleshooting in manual, but blinking at this high rate not described. Other monitors work with the computer. Cable checks out OK too. Shouldnt this monitor have lasted more than two years?????
  • Mazreth Apr 22, 2009
    I have the exact same problem. Tried several other monitors and all work fine. Swapped out cables and even tried the faulty monitor on another pc using the exact same monitor with same blinking blue ring of helldeath results. Please help!
  • dominikanito May 02, 2009
    The monitor worked for about 5 months and just now gave me the same issue the blue light around the power on button is jus t blinking rapidly and nothing on the screen pops up i have tried disconecting it for about an hr but nothing
    Problem Solver:
  • 6 Answers
See the tutorial below for pictures of what Roan described :
http://www.alexdemo.site90.com/#samsung2232bw_fix
Posted on Feb 01, 2010
    Scholar:
  • 29 Answers
Solution for Samsung SyncMaster 2232BWplus: Blinking power button.
The problem is bad capacitors: 5 pcs. 820microFarad – 25v and 1 pc. 330microFarad -25v. Replace these capacitors. Then re-solder the two transformers of inverter side. Also re-solder the power transformer and the inductor coil.
To open the casing:
At the bottom of the stand just twist the knob to unlock. Then pry by using a small flat screw driver beginning from the bottom (left or right) then using a hard credit card (or alike) then slide/glide it in between the cover plastics.
Good luck.
Roan
Triangle Tech Whiz
Posted on Jan 07, 2010
    Problem Solver:
  • 5 Answers
Try on diffrent PC if this works, plug it back in to the PC where it does not work, if it still does not work you need to reseat your grpahics card, still does not work? check the cabling, then finally if that doe snot work you PC is faulty.
Posted on Jun 06, 2008
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
Samsung 906vw blank screen
if the power light indicator is just blinking with no display, you must checked the power supply the common cause bulging electrolytic capacitor. just replace with the same value and rating then the problem solved.
Jul 22, 2012 | Samsung Computers & Internet
Samsung syncmaster940bw blackscreen with light blue blinking of its power button
That is a typical symptom of a failed power supply board. Here is a post that shows how to open the monitor and what to look for and replace to repair the unit.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/
I hope this helps.
BuddyMc
Apr 18, 2012 | Samsung Syncmaster 940BW LCD Monitor
Hi. I have a samsung syncmaster 940n black. After i turn on my computer the screen if just black and the blue light(where i turn the monitor on) just blinks.It worked normally yesterday.
The most common problem with the 940N units is a failure of the power supply/back light inverter board. This is easy to repair be replacing 6 capacitors on the power supply. Here is a link to a repair guide with dis-assembly instructions and what to look for and replace and the power board.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is the power supply board.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 17, 2011 | Samsung SyncMaster 940N 19 inch LCD...
Hey Experts! I need assistnace. My Samsung 2043BWX 20" monitor is black (or blank). I do have a flashing blue LED next to the power. When I plug the monitor in a power supple without being connected to the...
Actually, the ultra high voltage 'charger' for the florecence (a.k.a. your back light)has gone Kaput...
If your lucky, someone will have a monitor like yours that has the back light come on, but no picture (should get a similar blinking light situation, but a different code. Like... blink, hold, blink blink, hold, blink). In this situation (if your comfortable doing it) you can swipe the exciter from that monitor and put it in your monitor. Obviously this is a more economical way of repairing the monitor.
Just to be on the safe side (as the repair is blindingly easy. 6 screws, pop out, pop back in) DON'T touch any of the back side components. You WILL shock the supreme **** out of yourself. Between the heavy duty capacitors and the ultra high gain transformers on those things you could jump start a bus. So don't be fooled... those little transformers pack a mean sting.
Hope this helps...
Oct 11, 2010 | Samsung 2043BWX 20 inch Monitor
My monitor plugs in blue power button blinks why ?
There is probably a failure of part of the power supply pcb. If the light blinks and the screen is totally dark, this is the likely cause. The usual culprit is decective capacitors on the pcb. See other posts on this subject here. This failure may be intermittant; in other words, it may not always occur.
Jun 02, 2010 | Samsung SyncMaster 204BW LCD Monitor
Blue power light blinks and the monitor will not come on.
Look for bad caps with bulging tops in the power supply first, report back what you see so we can guide you further, see example of failed SAMSUNG due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 06, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
Monitor will not come on power light blinking blue
According to the manual, the frequency may be out of the range of the monitor. Adjust the frequency to the range needed by the monitor. Normally 60Hz will work fine.
Nov 04, 2009 | Samsung 941BW LCD Monitor
Computers & Internet Logo
534 people viewed this question
David Payne
David Payne
