Can you help me providing Holden Commodore Berlina VT 1997 radio security code
  • vh_44_1364 May 14, 2009
    i have holden commodore 1997, When i turn on the radio it turn off its self after 4 min and i also cant play cassette
    could you help me please? thank you
You must consider the bumble me as it flys through the sky and harvests on flowers
Posted on Mar 10, 2010
What each colourvwiringis for in vx ,2002,Commodore
The Holden Commodore (VX) is an executive car that was produced by the Australian manufacturer Holden from 2000 to 2002. It was the second iteration of the third generation of this Australian made model. Its range included the luxury variants, Holden Berlina (VX) and Holden Calais (VX), and it formed the basis for a new generation Holden Ute (VU) coup? utility and Holden Monaro (V2) coup?.
The VX series was produced between October 2000 and September 2002, as a minor restyling update to the VT series from 1997. It introduced greater model differentiation along with gains in crash safety. An intermediate Series II was launched in August 2001, featuring a revised suspension system among other changes.
Thanks,
Landon
Apr 16, 2017 | Cars & Trucks
My battery went flat and I jump started my car (Holden VT) now my stereo is locked. Dose anybody know how to unlock it. It's a eurovox radio unit.
Samantha, You need the VIN and the radio serial number. Take those into a Holden dealer to get the radio code and programming instructions from the dealer. They may want a small fee for the #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/131983-vt-stock-radio-cassette-player-security-code.html
Radio Security code Street Commodores Online Forum
Go Technologies Eurovox FAQs
Aug 26, 2016 | Holden Cars & Trucks
How do I find the stereo code for my VT Berlina
The Radio pin number should be on the security card inside the owners manual fold with log book.
Otherwise go into your local hen dealer and the can connect tech2 to vehicle and retrieve it.
Otherwise look it up on the online system .
Jan 30, 2015 | 1999 Holden VT
Radio wont accept correct pin no
there could be a couple of reason why it wont accept the radio pin.
Its possible that the radio pin you have is the orginal and maybe at same stage there was a fault with orginal radio and it was replaced under warranty the code wasn't updated .
Other is the bcm has been changed the codes hasn't been updated .
Jul 07, 2014 | 1998 Holden VT Commodore
How to fix climate control lights on berlina 1998 wagon
Here is a detail explanation of how to replace the lights.
http://www.lsxc.com.au/ozlsxforum/showthread.php?116-Change-VT-VX-climate-control-lights
Jun 10, 2014 | 1998 Holden VT Commodore
Unlock security radio code for vs commodore 1996 berlina
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Holden service centre and get them to enter this code for you.
Apr 09, 2013 | Cars & Trucks
Rough idle causes for a vt commodore 98 berlina V6 ecotec
Inlet manifold gasket loose (valley gasket) my vt was running like **** at idle only , tightened the 12 bolts near the injectors runs perfect now if that doesn't fix it the gasket may be wrecked $70 kit or get it done
Water was getting into the throttle body and into the cylinders causing irregular and irratick loping and rough idle it had me thinking it was all different things like leads , air leaks , bad fuel , bloked injectors , computers , coils
You'll probably find some loose one their is a torque sequence but try just tightening them start with middle side 4 first hope this helps and saves people money
Jun 13, 2012 | 1998 Holden VT Commodore
VT commodoore radio code
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Holden service centre andget them to enter this code for you.
Jan 27, 2012 | 1998 Holden VT Commodore
Vt Holden Commodore stereo wiring diagram
Here are the wiring codes for the VT,
VN-VT Commodores:
Accessory (12V) Yellow
Battery (12V) Orange/White
Ground (earth) Black/White
Antenna power (12V) Yellow/Red
Front Left + Tan
Front Left - Grey
Front Right + Light Green
Front Right - Dark Green
Rear Left + Brown/Black
Rear Left - Yellow/Blue
Rear Right + Blue/Orange
Rear Right - Blue/Black
Antenna Up White (VR-VT)
Antenna Down Blue (VR-VT)
Phone Mute Yellow/Black (VT)
Dimmer In (12V) Brown/White
Dimmer Out (12V) Grey (VT)
May 18, 2008 | Car Audio & Video
148 people viewed this question
 Grubhead
Grubhead
