Question about Toshiba e-Studio120 Copier
H4 error cannot fix problem even with instructions given :( error H4
    Sergeant:
  • 329 Answers
HEAT LOW CODE... FUSER NOT WARMING UP. FIRST RY TO RESET AS FOLLOWS. DEPRESS THE CLEAR KEY -THEN EXPOSE MODE KEY - CLEAR KEY AGIAN - EXPOSE MODE KEY. THIS WILL GET YOU INTO SIMUALTION MODE. DEPRESS 1 4 THEN HIT START. TURN OFF THEN ON. IF ID DOES NOT RESET FUSER PROBLEM. GOOD LUCK
Posted on Jun 12, 2008
Thank you very much. Ok.
Posted on Jan 28, 2010
Sharp al-2030 h4-00 code
H is a heater problem H4 is more specific, not sure but it could be the lamp, thermistor or triac. It will be one of these or even a bad connector on the heater section
Aug 28, 2014 | Sharp AL-2030 All-In-One Laser Printer
[H4-00]SHARP system error
A H4-00 error code is a problem with the fixing unit. Odds are you will need to replace the fixing lamp or thermal fuse or the thermistor to solve your problem. You did not tell us what model of Sharp you have? There are many different ways to reset the code. Good Luck
Dec 22, 2012 | Sharp Office Equipment & Supplies
My Printer is displaying an H4 error
The error code H4 means that you have a problem with the fixing unit. It could one of the item's > The thirmistor or thermal fuse or the fixing heater lamp
Oct 05, 2012 | Sharp Office Equipment & Supplies
H4-01
H4-01 is an error code that the fuser temperature is too low. This can be caused by a number of things, such as the copier wasn't given enough time to warm up, or the room was cold. You can reset this code by entering simulation mode. #,*,C,* Then press 14 and copy button. Reboot the copier, and this should clear the code.
Sep 27, 2010 | Sharp AR-M350U Copier
Error h4
H4 in 161, fuser low temp.; instantly solve it by simulation (c-auto-c-auto) 14; check thermistor; check fuser lamp by 5-02. it is to blink!
Jul 07, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
Error code:H4-00
That copier is kind a old. The H4-00 is a fusing error code. The problem is that the fuser is not heatting up right. Mostly it is that
the fusing lamp is broken or the thermal fuse is blown. It will not reset untill the problem is resoloved
Feb 16, 2008 | Office Equipment & Supplies
Cant get rid of blinking error message, nothing works
The [H4-00] system error popped up when the power went out of the house. I called Sharp tech support (1-630-378-3590) and was talking to their tech support in less than a minute.
The FIX? Just press the following keystrokes:
# * C * This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Dec 20, 2007 | Office Equipment & Supplies
422 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
