Question about Canon Office Equipment & Supplies
Cannon LBP3360 no slot load error - Canon Office Equipment & Supplies
Is the Canon lbp3360 laser printer wireless capable?
This model printer does not have wireless capability, BUT it has a network card that allows it to be connected to a LAN.
Network ready
Users can share the printer across a network with the built-in Network Interface Card. NetSpot Device Installer ensures quick and simple set up.
Jun 30, 2011 | Canon LASER SHOT LBP 3360 Printer
Cannon s2 digital camera used. i inserted a new memory card and have an error showing memory card error. card not locked!
trying removing it and unlocking it with the unlock button.. they some times lock them selves when you slide them in the slot.. go slow and straight.. this sometime fixes the problem... Good Luck.. T.
Jun 21, 2011 | Canon Cameras
How do you load the adding machine paper on this calulator #P23-DHV Cannon
Paper loads into slot at end of machine. After inserting end into the slot (at rear, near power cord connection) press feed button until paper advance thru top.
Jul 05, 2010 | Canon P23-DHV Calculator
I have the following error message:
SOMETHING MOST LIKELY FELL DOWN IN BACK PAPER PATH OR TORN PAPER THAT HAS PAPER SENSOR STUCK. HARD TO SEE SOMETIMES. MIGHT WHAT TO TURN MACH UPSIDE DOWN AND SHAKE BE VERY CAREFULL
Apr 14, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Cannon MP600-where do you see Error Code? I just get "Paper output slot" paper is jammed; but it's not!
That error usually comes from the sensor under the platen roller. It's a tiny black plastic piece that the paper pushes when it passes under the platen roller. The end can bend when you pull out a jam, or a tiny paper scrap can hold it down. The same screen gives error codes when there are other malfunctions, the error now is just that sensor.
Dec 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
How do i load my phone sim card into the cannon mp480 printer as
Of course it is to small. You need to connect your phone with the adapter that originally came with it into your usb port
Apr 01, 2009 | Canon Office Equipment & Supplies
NOT TAKING TAPE
I have one doing the same thing. I called Cannon and the told me I would have to send it in for service. Now after reading that about 10 other folks having the same issue, I think Cannon has some issue with the ZR100. Of course mine is out of warranty. Everyone should call Cannon and complain.
Apr 09, 2007 | Canon ZR100 Mini DV Digital Camcorder
124 people viewed this question
old marine
old marine
