My monitor is displaying all red how can i fix this when i switch monitors it is still red.
  • Paul Ward May 11, 2010
    When you change monitors are you using the same computer and monitor cable?
    Sergeant:
  • 458 Answers
Did you check the sleep mode or power off mode? What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Not sure how to diagnose this without seeing it myself. That is the best that I can do. Your video card could be going bad. Try another video card on that monitor. This will be the only way to decide if it is the card or monitor. Try it on another machine or with a different cable if the cable can be taken off and see what it does.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future. If you need more help, feel free to keep asking, but keep the original information so I can see it.
Posted on Jun 06, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you solve your problem? Let me know if you are still having problems so I can help you more.
    Are you still having this problem? Did my answer solve your problem?
    Rate this as a Fixya if it is fixed.
How to Fix display problems ( red display, or only for about 2 seconds display)
There are two problems, screen goes black after 2 seconds, red only. The problem is in the video processing board located on the back of the picture tube, it is well shielded against outside interference.
Apr 07, 2012 | IBM J156-1702 17 in.CRT Conventional...
LCD MONITOR DISPLAY PROBLEM
What your describing is a major video problem, poor color and it is blurr, It would be far cheaper to replace the monitor with a new one.
Mar 08, 2012 | Samsung SyncMaster Computers & Internet
The pc is ok and log in normal, but the screen is red. Is this the card or can I fix it
This problem is typically a monitor problem. Firstly check all the connecting pins of the monitor vga cable where it plugs into your display card. Sometimes these pins are either bent or pushed into the plug and do not make proper contact with the card pin socket.
The quickest way to determine the fault would be to plug in another monitor & see if you get the same red screen. If the other screen also shows up red, you can safely rule out a faulty screen & just replace your display card. My guess is that the other screen will display correctly & you will have to repair or replace your own screen.
Let me know if you need any further assistance.
Best wishes,
Graemevm
Mar 04, 2011 | LG Studioworks 99T Monitor
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Red colour missing
hello
red colour if missing from mother board then you can fix it from graphics properties of your mothrboard driver
but red may also due to monitor,there should be black colour appeaqrs on screen instead of red.
to solve this you have to take your monitor from where you have purchased
if it is in warranty or gurantee then dont take to third party
the fault in monitor may be due to
fault in monitor cable
also check that cable is not loose
try to plug the cable on cpu again
another fault is inside the monitor
also try to on monitor using detaching monitor cable from cpu,message come on monitor ,if in that message red colour appear,then monitor gun is ok
and problem is in monitor due to desoldiring
if you know about soledring than you can fix this problem yourself only if you know otherwise take it to shop from where you sold it
Nov 22, 2008 | Intel D101GGC Motherboard
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
CRT-Monitor
my e70fsb monitor is self adjusting, brightness goes to maximum
Aug 05, 2008 | Computers & Internet
Can you help me to fix my monitor?
Check the connector of the Pc sometimes if don't put it right make those simptoms.Good luck
Jun 03, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
About colors
It sounds like either an internal wire is loose, or possibly in the connector to your video cable. Make sure the connections for your video cable are tight both at the computer and at the monitor. If they are, try a different cable (cables are much cheaper than monitors, always start with the easy solutions first). If the problem is internal to the monitor, then it is up to you to decide whether to try to diagnose/fix it yourself, or buy a new monitor. The cost to pay someone else to fix it is likely more than the value of the monitor.
Feb 21, 2007 | SAMTRON 55V 15" CRT Monitor
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
