Modem says no dial tone, phone line is ok. Also USB ports wont work with flash drives.
Notebook modem wont read dial tone and i use this phone line on my desk top computer all the time. How do I fix this, or if i need to replace the modem how do i get inside notebook to do it?
Also my USB ports wont work with flash drives. I tried to use 2 flash drives that i use all the time on other computers and the notebook says un-reconised device or no driver installed for this device. How can i fix this?
  • 3 more comments
  • pitman3 Jun 06, 2008
    This is a Toshiba A135-S2256 satellite notbook pc
    Completed a full boot time virus scan, no problems
  • pknauf Aug 05, 2008
    inspiron 4000. Modem does not work--says cannot find dial tone but phone works on line I have a parts only inspiron 4000.. How do I replace the modem?
    What screws do I have to loosen?
  • swatkins12 Aug 21, 2008
    I'm having the same problem with my Compaq laptop. My computer says no dial tone but I know the phone line and jack work. I've scanned my computer and no viruses are found. Any ideas?
  • flexer May 11, 2010
    I had the same problem with modem at notebook. BUT at another phone line (at another location at the same time) modem works fine.
    I have removed "wait for dial tone" at modem-driver settings, then it start works! I can not specify an exact setting name in English - seems there something like "wait for dial tone":
    1. open "Computer management" tool
    2. open there "Device manager" node
    3. find modem and open it's properties
    4. On the second tab "modem" at the bottom there is a check box
    something like "wait for dial tone".
It could still be your phone lines they may have static in the line the att phone company in rockford sucks Ive had this problem on and off for 6 years
Posted on Oct 09, 2008
  • 2,785 Answers
Plz check your pc for viruse then post your findings for further help
Posted on Jun 06, 2008
The tel 1 and 2 buttons are flashing green along with stand by. The phone line has no dial tone and its busy when we call the line..
When the tel light blinks this indicates that the line is in use. To trouble shoot this issue you will need to connect a phone directly to the tel 1 port of your modem. If you have dial tone when directly connect that means that there is an issue with the internal wiring of the home. If you still do not have any dial tone with the phone directly connect than there is an issue with the modem and it needs to be replaced.
I hope that information above has helped is some way.
If possible please rate this solution.
Aug 25, 2010 | Arris SURFboard SB5120 Modem
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
My acer laptop is not getting a dial tone but the phone line is good. If the modem is bad, where is it located on the laptop?
Hello flubber20054,
The modem settings can be accessed through the windows control panel as follows:
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
In the Control Panel, do the following:
•Select Phone and Modem Options (Brings up the phone and modems properties sheet)
•Click on the 'Modems' tab
•Highlight the modem's name
•Click the properties button
•Look for the words 'Device Status' on that page.
If the message box says 'This device is working properly' then the modem is working ok. The Phone and Modem Options also has a tab called 'Dialing Rules'. The dial tone might work if you 'Edit' the existing Dialing Rule or Create a 'New' Rule. When you 'Edit' or create a 'New' rule, enter the requested information as best you can. You can always go back and 'Edit' the rule to keep testing it. I hope this gives you some ideas for resolving the dial tone problem.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
Aug 04, 2009 | Acer Aspire 5720-6661 Notebook PC
My Epson bx300f cannot send faxes, just says no dial tone?!!!
ALL fax machines are ANALOG devices and will not work on a DIGITAL PHONE LINE.
Jul 06, 2009 | Epson Stylus Multifunction Printer/...
Computer modem and dial tone
Hello Mikenrgrsvll
This problem can be due to the software not handling a certain dial tone rather than a specific hardware fault. Around the world there is a variance in the signal quality of the dial tone which causes a report of no dial tone detection. Disable the dial tone detection to prevent the system from trying to detect a dial tone.
Disabling dial tone detection for modems:
Windows XP
  1. Click Start
  2. Select Control Panel
  3. Click Switch to Classic View to change the control panel view
  4. Click Phone and Modem Options
  5. Select the Modem Tab
  6. Select the installed modem (Example: Lucent Technologies Soft Modem AMR)
  7. Click the Properties button
  8. Select the Modem tab in the Properties window
  9. Click Wait for dial tone before dialing to remove the check from the checkbox
  10. Select the Advanced tab
  11. Add X3 to the Extra initialization commands field in the Extra Settings box
  12. Click OK twice
  13. Select Switch to Category View to change back the control panel view
  14. Close Control Panel
if this does not work trying re-installing modem drivers.
hope this helps, have a good day.
May 04, 2009 | Acer Aspire One PC Notebook
Modem problem
Disconnect the phone line from the modem and connect a normal phone to this phone line. Lift the handset and check it you have a dial tone and see if you can dial out.
If you don't get a dial tone then there is a fault with the phone line and it needs to be repaired before you can use your modem.
Apr 14, 2009 | Dell Latitude C640 Notebook
Connection a Netbook to dial up
if your netbook doesnt have built in dialup modem that mean u cant connect it to a dial up connection. most of netbook in market use wifi as primary connection or sometime comes with built in GSM modem to connect to internet. that meanc the option you can try is to buy a external USB dial up modem
Mar 26, 2009 | Advent 4211c Notebook
Modem stopped working
Well its sounds ike the modem may poked ut lets assume it is not perhaps yo have doube checked your conection is correct if it is TRY ANOTHER modem because they are known probems for your coonections especially dialup are you meaning this?
Jul 13, 2008 | Toshiba Satellite A135-S4527 Notebook
Trying to launch internet gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
No Dial Tone on phones or modem
if you have a dial tone when your computer is not plugged in, then the problem ls with your computer[ a possible short in the computer] the phone cord to the jack, or anything in between such as a dsl modem.if you have dsl, be sure your ethernet cord [ that's the wider plug cord] is in the wider jack in back of the computer. it wont fit in the regular phone jack.if you have dial up, be sure the phone cord is in the regular jack not the ethernet port.[if you have one]
good luck
Jan 30, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Computers & Internet Logo
679 people viewed this question
David Payne
David Payne
