Question about Canon PIXMA MP530 All-In-One InkJet Printer
Replacing ink chip on IP3500
As my printer is new I had just run out of ink. I followed the instructions for taking cartridge off of empty one and replacing on new. replaced them in printer. Now evertime I go to print I get a msg saying if I attempt to print when ink empty I could damage my printer. This msg only gives me a cancel button or tells me to press resume on my printer if I want to contine printing. I am frustrated by this is it something I have done wrong or is this a common problem when changing these chips??
    Genius:
  • 2,035 Answers
These is the common problem when you buy new cartridges which have kept over long time in the shelf ..If these are new cart and original please contact the company and get it replaced as the new cart comes 6 months warranty.........................
Posted on Jun 06, 2008
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
My Canon printer is pixma ip 3500. My printer is blinking and when i want to print there is a message "the ink absorber is full". Please help me what is the solution? Thank you very much.
All inkjet printers have a waste ink tank for ink which does not make it on the paper. When it's full, the printer stops working. You might be able to reset the counter in the printer, but unless you also emptied the tank, it won't help. It's like using a chip resetter to tell an empty cartridge it has ink. The "out of ink" error will go away but you still can't print. Unless you want to go through the tedious and messy process of emptying the ink tank, you are best off getting another printer. They're practically disposable today.
Mar 06, 2011 | Canon PIXMA iP3500 Printer
How to remove ink
http://support.dell.com/support/edocs/systems/PRN810/en/index.htm#online_documentation
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
Check color printer cartridge--I refilled the cartridge the orinter doesn't accept it"
Hi
When a non professionals refill there cartridges
air bubbles are left in cartridges durring refilling process
so when cartridge need ink to heat and spray it on paper has air and that time is when is getting overheat it and need to be replaced
check here how you can refill it your cartridges with no errors on your printer
In case I had help you pls vote me
Oct 28, 2010 | HP Photosmart 2575 All-In-One InkJet...
Our new Epson Stylus TX110 used up the initial introductory black ink cartridge. Upon replacing it with an authentic Epson ink cartridge, the printer keeps saying it is empty of black ink and will not...
Check for chip connector at ink tank and at head carriage. Do replacement procedure from Epson Status monitor, follow How to.... Whhen asking to replace, unplug and plug back again securely. Or you can take to epson service center for guarantee.
Mar 15, 2010 | Epson Office Equipment & Supplies
The light for the magenta cartridge on my iP3500 printer goes off
The cartridge, as well as all ink jet cartridges has a chip inside that tells it how much ink is in the cartridge. Your cartridge is LYING, except it prevents you from printing without all cartridges working. ( same for my 6 color epson ). You need to replace the cartridge. I get my cartridges at a yahoo store called Inks4less. They have good quality for cheap.
There was a study done, analizing the amount of inks left in inkjet cartridges when they indicated empty, and the range was 7% to 25% ink still left.
Oct 03, 2009 | Canon PIXMA iP3500 Printer
I refilled my empty ink cartrage, but the printer still says its empty and to replace the black. how do i reset it to say full?
without make or model number, cant do anything. Check to see if there is a chip somewhere on the ink cartridge. If so...your screwed. Some printer have a 'is this a new cartridge', follow the instructions.
Apr 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer error requests that a full ink tank is empty.
You can try cleaning the electrical contacts in the printer and on the cartridge with isopropyl alcohol followed by water to see if that fixes it. Then you can try removing all your cartridges, turning the printer off, unplugging it, waiting a few minutes, plugging it back in, turning it on, and waiting for the printer to recognize there are no cartridges installed before you reinstall the cartridges. Otherwise you may have damaged the chip on the cartridge with static electricity when installing it. If this is a new cartridge I would return it to the store you purchased it from and ask for a replacement.
Jan 26, 2009 | Canon iP3500 Photo Printer
Replaced ink cartridge printer continues to say no cartridge
you need to follow the whole procedure on your to ensure proper installation as soon as you install the new one, follow the instruction on the screen to calibrate your new ink
Nov 08, 2008 | Brother MFC-440CN InkJet Printer
Compatible Cartridge
if the cartridge has a micro-chip on it, it,s possible that the cartridge has not had the Chip recharged after being filled with ink.
Alternatively, go to printer properties or preferences, and locate Maintainance. If there is an icon to change ink cartridges, follow the on-screen instructions of how to.
On installation, if you get a message stating :- the following cartridges are not the original items, do you wish to proceed. select yes. If this fails, look on the web, to see if you can obtain A Chip-ressetting tool for your model printer, or if there is a suitable ink re-fill kit available.
Mike @ Compurepair.
Aug 19, 2008 | Epson R1900 Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
82 people viewed this question
old marine
old marine
